new guy
andyman450r
    • By Drillbit
    • By FalloutBoy
      Hello everyone I'm new to the forum.
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
    • By WillrogersII
      Just picked up a 1998 bayou 300 4x4, runs but spits and sputters. runs worse when i put on the air filter. guy said it has a brand new carb. Does adjusting the valves help with the cold start and not run right until it warms up?
