By Clydaho
2022 Sector 550, 414 miles on it and the gas gauge reads empty. I topped off the gas and it didn't change.
There is no fuse that I could find. No access at the gauge cluster.
Has anybody removed the tank lid? Any tricks?
Any other ideas?
Thanks for any help,
Clyde
By HSTAR
By Suzukiquad
I just bought two 2002 Suzuki LT80K. Do I need to mix the gas or use straight unleaded?
By ResQ91
Hi guys
battery and connections good
By Bobbywolf
I am working on a basket case for a friend. It is a 98 Big Bear (YFM350FWB). It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
Anyway, first thing is first. I checked compression, 150psi. Valves are set correctly, and the engine is in time. I cleaned the carb, and there was some junk in the passages. It is a chinese carb, which I figured from the lack of markings or lettering altogether.
The bike runs. It idles ok, but breaks up badly under acceleration. Pulling a new spark plug shows it is running lean. White strap, with no black whatsoever. So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot. It is still not getting enough fuel (or too much air). It backfires through the carb, and cannot get above idle without carrying on. The carb boot is in good shape, so it isn't pulling any air there. I did test this as well by spraying ether around the boot when running, looking for intake leaks.
Anything big I am missing here? I am starting to believe that this chinese carb is the issue. This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
Thanks for any assistance.
Similar Tagged Forum Content
- 3 comments
- 2,562 views
- 0 replies
- 2,253 views
- 6 replies
- 2,690 views
- 0 replies
- 1,617 views
- 0 replies
- 1,563 views
Recently Browsing 0 members
