Rancher 420 2wd to 4wd conversion
killer420
I know this has been talked about, so i did some research.
After my research, i started buying parts.
Here are the parts you need:
51380-HP7-A00, left front upper control arm
51370-HP7-A00, right front upper control arm
51350-HP5-600, right front lower control arm
51360-HP5-600, left front lower control arm
44615-HP5-600, front drive hubs (need 2)
53521-HP5-600, tie rods (need 2, this is just the adjuster rod, not the tie-rod ends)
51200-HP5-600, right steering knuckle
51250-HP5-600, left steering knuckle
53235-HP5-600, steering arm (connects the tie rod ends to the steering shaft)
23611-HP5-600, "final shaft", goes inside the engine, provides power to front and rear driveshafts)
40400-HP5-600, front driveshaft
44250-HP7-A31, right front axle
44350-HP7-A31, left front axle
11300-HP5-000, front crankcase cover
50350-HP5-600, front differential support bracket
41400-HP5-A50, front differential unit
You also need the 4wd shift lever and the cable that connects it to the differential. there is not a part number for the whole assembly, just look on ebay. thats where i got mine.
Now on to the good part, the turning of wrenches:
Here is the engine before removal:
after removal:
front differential in position:
^^^notice the "TRX420TM" decal, indicating 2wd
Here is a pic of the "final shaft", comparing the 2wd (in my hand) to the 4wd (in the engine).
^This is the most difficult part of this conversion, removing and opening the engine to swap out this shaft. However, there is a lovely video on youtube showing how to rebuild this engine and they clearly show the steps to remove/replace the rear cover and final shaft. Dont forget to remove the front cover before installing the new shaft, it will not fit thru the 2wd front cover.
link to video>:
once the new shaft is installed:
you will need to install the front and rear covers using sealant, make sure all shims/washers and o-rings are in place in the correct locations referencing the video above.
here is the right front corner mostly assembled:
and fully assembled with hub, rotor, and brake caliper:
I do have more pictures to upload, when i have more time i will update this further
  • 9 months later...
if anyone cares (which i doubt since its been 9 months since i posted this), i only spent $750 on the conversion overall. everything worked flawlessly first try. i used this honda to plow 30inches of snow from a steep 800ft driveway. never missed a beat.
it was WAY cheaper than selling my 2wd rancher at a big loss and buying a 4wd version. if you can turn a wrench this is not too difficult for you to do at home
Edited by killer420
  • 8 months later...
it will probably cost a little more than it did for mine, i was able to source some a couple used parts for much less than new. For instance, a new front diff for mine was $675, i got a used one for $80. it may be more difficult to source used parts for such a new machine.
from some quick poking around on rockymountainatv.com using their Honda OEM catalog, it appears you will need to change your front knuckles, get front axles and differential, change front cover on engine, change final shaft in engine, change front tie-rods, add 4wd shifter and cable
if i have time tonight after work i will try to get you a list of part numbers you would need
  • 8 months later...
  • 3 months later...
  • 8 months later...
  • 2 years later...
I know this is an old post, but I too have the same 2W ATV and this would be so helpful for snowplowing, because with 2W drive you can forget about it.
Thanks for showing us the way, cost and pictures!
  • 7 months later...
Hey so I have done a ton of research because I have the same foot shift two wheel drive rancher and so what I’ve come up with is all you need is a front axles, front propeller shaft, the final shaft inside the engine and the front engine cover, wears it final shaft sticks out of. I will list all the part numbers for everything that you need and prices from about six months ago (sorry) , you DONT need to switch out hubs, knuckles, or anything like that, and if you want differential lock lock like the foreman and Rubicon you can just get a foreman Rubicon front differential and propeller shaft with the diff-lock and get a sure four manual actuator for it and voilà you have four-wheel-drive rancher
Note: since you guys were mentioning snow plowing, I would definitely get the aftermarket HD axles because they are definitely stronger and are around the same price as oem
FINAL SHAFT
23611-HR3-A40  =$80.48
BEARING
91006-HP5-601   =$11.11
OIL SEAL
91202-HR0-F01   =$ 7.94
COVER ASSY., FR. CRANKCASE
11300-HR3-WB0   =$206.99
PROPELLER SH AFT
40400-HR3-A20   =$91.50
FINAL GEAR
41400-HR3-W50   =$714.88
FINAL CASE BRA CKET
50350-HR3-A20  =$7.40
FLANGE BOLT
95701-08016-08  =$1.49
R. SHAFT SET
44250-HR3-WB1  =$240.64
L. DRIVESHAFT
44350-HR3-WB1  =$240.64
This is all for the 2x4 - 4x4  lever that comes in stock on the ranchers. I would definitely recommend looking for parts for wheelers on marketplace,  or craigslist
001
NUT, ADJUSTING
41560-HP5-600
$6.51
002
CABLE, FR. FINAL CLUTCH
41570-HR3-A21
$6.56
003
SPRING, CLUTCH CABLE
41571-HP5-600
$1.95
004
CLIP, CLUTCH CABLE
41573-HP5-600
$3.23
005
GROMMET, CLUTCH CABLE
41716-HP5-600
$3.12
006
LEVER, FR. FINAL CLUTCH
54030-HP5-600
$8.91
007
PILLOW BALL, FR. FINAL CLUTCH
54031-HP5-601
$10.87
008
BRACKET, FR. FINAL CLUTCH
54040-HP5-601
$11.19
009
SPRING, FR. FINAL CLUTCH
54041-HP5-600
$1.86
010
GATE, FR. FINAL CLUTCH
54050-HR3-A20
$4.55
011
GRIP, FR. FINAL CLUTCH
54321-HP5-600
$8.95
X2 012
BOLT, FLANGE (6MM)
90111-162-000
$2.54
013
NUT, SELF-LOCK (6MM)
90343-ZE6-000
$1.70
014
JOINT B, BRAKE ARM
95015-32001
$0.82
X3 015
BOLT, FLANGE (6X12)
95701-06012-00
$1.34
Or Forman 520 w diff lock
FINAL GEAR
41400-HR4-A21  =$732.49
PROPELLER SHAFT
40400-HR4-A20  = $92.54
And you definitely need the sure four locker for this
How do you figure the front hubs and steering knuckles aren't needed  ?
And I presume since Killer in the first post reckoned we needed the steering rods and new upper and lower suspension arms, that they will be needed too ?
I have come to this conclusion because if you look at the parts diagram the steering, a-arms, and knuckles are all the same part numbers even up to the foreman and rubicons the only difference is they’re is a “puck” instead of the cv axle as seen in this picture
(it’s number 8 that I’m talking about)IMG_0270.thumb.png.1af0d1b035e8981de80f82581f85b490.png
#15..  Oh ok.  You're right. Good spotting. I've never seen one like that, but I'm in New Zealand. Over here all the 2WD have a stub axle as part of the knuckle.
I still think you'd have to be careful to check exactly which model you have.. Some might not convert that easy. Not everyone gets the same spec bikes as America does.
They can have different specs in different markets, even when the model suffix is the same in some makes, and what's one year's model  in one country, can often be another year for another country too.
Anyone thinking of doing it really needs to check their exact bike against the parts lists I think.
    • By mehim
      Hi everyone.
    • By Its-always-something
    • By Charlesbrown
    • By gatorschevy
      04 Suzuki Quad runner 400
      86 Kawasaki bayou 185
      96 Polaris magnum 425
      95 Polaris trail blazer 250
      03 bombardier 175 rally
      92 Yamaha moto 4 350
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
