2005 Kawasaki BF 750;Coolant & pressure in crankcase
pete
I've got a 2005 Brute Force 750 that just had the main timing chain replaced (It broke) along with a couple valves (Bent). The engine work was done by my Mechanic but I removed & reinstalled the motor.
Put it all back together and it fired up nicely. I let it idle for a bit and pulled the dipstick to make sure I hade enough oil in it. Major pressure coming out of the crankcase, it was as if I had my hand in front of the exhaust! Tons of coolant in there as well!
The guy who rebuilt it is very good and I know I put it all back together correctly. He obviously missed something, anyone have any thoughts?
Thanks,
Pete
Coolant in the crankcase  sounds like a cracked block  or head to me; although if the head and block  have  water passages  between them  . it could be a head gasket  problem.  Rings and valve seals will  not  let  coolant into the  crankcase ,  but  a bad head gasket or cracked block or head will  let  pressure  and coolant into the crankcase.
If there is coolant getting into the crank case you would probably have coolant and oil mixture and cause a milky result. If coolant is getting into teh combustion chanber, you'd have a good amount of white smoke when running. Either can be a head gasket, seal, or crack somewhere.
a missing seal or broken o ring in the coolant passage will also let coolant into the crankcase.
i never said valve seals will let coolant into the crankcase i simply asked a question re the valve seals as were they replaced.  Blowby comes from a broken or worn rings and usually when a valve job is done valve seals should be replaced. a broken gasket anywhere in the coolant train will allow it to gather up in the sump.
    • By BruceG
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By kantrud97
      Thank you in advance
    • By p5200
      Hello, what is the best method for installing bearings into their race? I've set one in place and tapped it down until it was metal on metal. Is that sufficient? Surely it's not supposed to go into the race until flush? Also. does the coil spring on the seal go into carrier bearing housing not facing out? Thanks! 🙂 Seal goes in until flush correct?
