By kiriyaaoi
By Mhatayas
By Charlesbrown
By Sofaspud
By adr94
Hello,
I was able to repair most of the little problems on my 2006 BRUIN. I still have little things to do...
I changed the Hazard light Switch because it was not locking when pushed and now it is not working at all. When I connect it (not sure of the wiring -4 wires but a lot of connection possible on this HELLA 3916-01 switch-) the flashing lights button (on the handlebar) is acting like the Hazard light switch.
Similar Tagged Forum Content
- 1 reply
- 3,064 views
- 4 replies
- 3,218 views
- 1 reply
- 3,179 views
- 23 replies
- 3,222 views
- 6 replies
- 3,395 views
