By Suzukiquad
By Suzukiquad
I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
By Bobbywolf
Thanks for any assistance.
By p5200
By joshua91673
first post
josh ohio
Similar Tagged Forum Content
- 6 replies
- 9,575 views
- 5 replies
- 2,593 views
- 13 replies
- 23,504 views
- 6 replies
- 2,894 views
- 7 replies
- 4,512 views
