Project 2008 Polaris Ranger RZR Suspension and Seating
I was at an obstacle course comp. this weekend. My girl was competeing in her Rhino. She was up against a 08 RZR. He got high centered on the log crossing and rolled through one of the turns. The Rhino made everything perferct except one big sand hill. Both machines got high centered on that.
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
    • By prdicon
      South Florida.
      How much it worth?
      Pros: looking decent.
      Cons
      No brakes.
      Front wheel bearings are shot.
      Idles, but sometimes will shot off. Most likely when cold.
      Gas smell and little bit steam in the air filter box when I started it.
      Display screen won't work.
      Tires are dry with cracks.
      Not sure if has title, I will check and update.
      How much do you think it worth?
    • By miszhang
      View File 2017-2020 Polaris RZR 570 / S 570 service manual
      Submitter miszhang Submitted 04/24/2023 Category Polaris ATV
    • By PF3
      Rzr has been sitting unused inside garage for about 18 months. Engine started and run about 15 min every 1 or 2 months.  Never any problem starting or running. This week took it out of town to ride for a day. Loaded, unloaded with no problems. After unloading went trailing. After about a 1/2 mile we went down a small kill and started up another hill and engine died. Restarted many times and died each time after only free seconds. Brought it home and started several times with same outcome.  Changed to fresh fuel and started it.  Lasted about 90 seconds (at idle) and died. So we started it several times and revved the engine up and it continued to run (while still revved up) each time until we dropped it back to idle and it died each time. HELP! Please.
    • By afa913
      Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
