SunLrider
dual exaust
30 posts in this topic
i was just wondering if i could find a super sweet dual exaust for the blaster, just an idea,
Share this post
Link to post
get some metal pipe get a welder and a pipe bender.... make the curtain bends needed to come from the engine to the back... and then weld it all together... and then buy to mufflers... or u can use the one u have now and buy the same one.....
Share this post
Link to post
hah sounds expensive,
Share this post
Link to post
i dont think it is that expensive u just need to know wat ur doing.... i think a 250 with a dual exhaust would be sick... but u r probably making ur engine struggle more...
Share this post
Link to post
once the money floods in im gettin one of those 240 kits for like 200 bucks:wink:
Share this post
Link to post
A dual on your ride would look sick but it would be a waste of money, in my opinion.
Share this post
Link to post
BINGO! a dual is jus for looks basically. an FMF or pro curcuit pipe would produce as much if not more flow than the dual.
IMO the duals look sick but not worth the money. spend that extra cash on other needed stuff like suspension, tires, etc
JMHO
Share this post
Link to post
JMHO
i was just making an idea
Share this post
Link to post
Do it up, you would be the first that I've seen. We're not knocking your idea just letting you know with the amount of money you will spend on 2 silencers and fabing a mid pipe and header it would be over kill for that bike. Only 2 machines have any business running duals, the Raptor and the Banshee.
Share this post
Link to post
i just dont want to screw it up so that i cant have a running quad anymore
Share this post
Link to post
It will run but you will lose power. You only have one exhaust port on your motor, if you put a "Y" connector in line of your exhaust the exhaust will not flow smoothly.
Share this post
Link to post
ahhh, i see
Share this post
Link to post
dont forget bot the sportsman 800 comes stock with a double exhaust
really? thats sweet
Share this post
Link to post
Have you checked LTE. they make duals for a number of makes and models.
Share this post
Link to post
kfx700s are BEAST with duals on also.
any vtwin NEEDS duals IMO.
not just duals. TRUE duals.
duals are sweet..but on a two stroke?
thats just weird..because the header is like really wide
it would be weird...
Share this post
Link to post
banshee is a two stroke and has duals. only because it has 2 pistons.. if you don't have 2 exhaust ports duals are a waste..
Share this post
Link to post
banshees are a givin. they are twins.
but a single cylinder...
is it possible?
or would it just make you have like NO gains.
Share this post
Link to post
The only gain you will get from running duals on a single cylinder is the number of looks.
Share this post
Link to post
im thinking of like the flow though...wouldnt it mess it up?
unless you split them at the silencer or something.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
