Jagged X RANGER RZR Wins Best In The Desert's Bilek Silver State 300
quadcrazy
The team pulls off another win! - 10/07/08The Jagged X/Polaris Racing number 1919 team was able to pull off another win at the Bilek Silver State 300, in Mesquite Nevada. Jagged X started in second place with a smaller-than-usual field of only five vehicles.
The Mesquite venue was billed as a new race course but the drivers soon discovered that Casey from "Best in the Desert" still had plenty of tricks up his sleeve. Co driver, Blake Van de Loo noted that the course had, "The most silt ever but also was loaded with a huge variety of terrain from 7000 ft pine forest to a trip through the old mining town of Caliente, Nevada, and even some pretty deep water crossings."
The Jagged X RANGER RZR moved into the lead shortly after the start when the lead car encountered engine trouble. A little more than nine hours later, Brandon and Blake crossed the finish unchallenged to score their third season victory and to further secure the lead spot in the 2008 BITD points chase.
The next BITD race is the Golden West 150 (formerly the AVI 150), in Jean, Nevada, on Oct 25. This is a Quad, Side-by-Side and trophy lite only race and promises to be an exciting event.
Donna Beadle
External Relations Specialist-ATV & RANGER
Polaris Industries
763-542-2314
Photo Gallery: Jagged X RANGER RZR Wins Best In The Desert's Bilek Silver State 300 - ATV Rider Magazine
Read More | Digg It | Add to del.icio.us
More...
    • By hardcastle
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Its-always-something
    • By Lafytafy
      should i run a thicker oil in a older quad because it make a little more noise than usual
      CARFAX https://www.carfax.com
