By STLJ
Hope everyone is having a great weekend,
While riding my quad just quit, I mean dead. No life on the dash, no crank and obesity no start.
Had a quick look under the plastic, batt reading 12.7v power at the key switch.
Changed the power pack, still no luck.
Anyone else have similar problems?
I don't see a fuse box/panel, is there fusible links in the system? If so where di I start looking?
SK
By Dohbezon
Hello everyone,
I'm excited to join the forum today! My name's Noah and I am 30 years old. I look forward to gaining new knowledge, sharing my experience and benefiting from members' insightful advice.
Thank you in advance for the welcome.
By kawasig
By beast6228
It's been a long time since I have used a forum, I was the admin of one for quite a few years, had thousands of daily active members, with lots of crazy posts and spammers, so I salute the admins. Anyway, just waving my greasy hands, Hopefully I can help others out.
By Params_sweden
Hi!
I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
I'm thankful for all the help and pointers I can get, don't hesitate
/ Pär, Sweden
Similar Tagged Forum Content
- 3 replies
- 27,464 views
- 4 comments
- 3,056 views
- 6 comments
- 2,799 views
- 0 replies
- 7,617 views
- 0 replies
- 2,156 views
