08 YFZ450 Want to change sprocket
mikaveli
Changing to a smaller sprocket will give you more low end performance. I think that droping a tooth in the front may not be the best idea, you will lose alot of top end speed,you will lose traction and you will run the gears out faster. You will be spinning your tires like mad and you will be on the rev limiter before you know it. Some people do it and seem to like the result but, going up a tooth or two on the rear would be better IMO, you will get a little bit better low end without sacrificing too much top end speed. Changing rear sprockets is just as easy and the change is more subtle, however, a two tooth change may require a link added to the chain. Generally, a one tooth change in front is comparable to a 3 tooth change in back. Like Bot said, exhaust and cam upgrades will help you with more power that will help you pull the stock gearing a bit better, obviously that would be the best way to go but if you only want to spend about $20 to $35 dollars or so, sprockets are much cheaper.
I have Two Brother exhaust (slip on) and have K&N filter top off it seem i got good power and speed it dies alot when i try to take hills and when it gets hot it likes to stall when i take off thought maybe a
Boyesen QuickShot 2 would take care of it dont have money for it now a friend gave me the sproket thought it would help
If you got the sprocket, try it, you can always put it back if you don't like it, it is easy enough. But it sounds like you have other problems. Did you re-jet the carb when you added the exhaust and filter? You may be running that thing a bit lean, lean is bad. I would make sure your jetting is ok before you ride it again. Pull your plug out, what does it look like?
    • By McG75
    • By DarkRider
    • By luckyyyyesther
      Hey all!
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
    • By p5200
