By rgeiser
By Tuzz
By p5200
By Traytonrowland
So, I bought the machine almost a year ago and have been chasing problems. I have replaced the battery, starter solenoid, spark plug, and the starter. Since having replaced those, it doesn't want to start. I checked the carb, and it was wet as well as the spark plug. And I've searched multiple forums and cannot find an answer. So, anything that helps is appreciated, thanks.
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
