By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By Robin442
Hello all! New to the site, I came here seeking answers as I've decided to help my cousin get his once good running buyou 220 going again.
I've owned an 82 kawasaki kz1100 and have done lots of work to it over 20 years of ownership.
Looks like the wire diagram colors are same or similar to my bikes wiring, a definite plus
Cousin was riding through fairly high weeds and brush after it's rained, when it just died. It would turn over but no fire.
This to me sounds like perhaps a CDI issue or a fried coil, idk that why I'm asking you gurus LOL
By lindzjo
Does anyone have a service manual for Qlink 700 atv.I cant find anything on one.Please help
By Domshook
I recently got a 2003 yamaha kodiak 450 with a bad starter clutch. And when i go to replace it i noticw there is no woodruff key and the brass bushing was split. Now i have to basically press on my idler gear. Im pretty sure this is wrong and i need help i have tried 2 different companys. Please help. There is no play in the crankshaft and no obivous marks or wear signs.
By JacobL
I cleaned the carb took it a part let it set for 3 hours And I put it back in and was leaking gas out the overflow tube fixed that now it starts but only with choke on and runs rough turn the choke off it dies idk what it is
