Sign in to follow this
Followers 0
utvboard
Polaris RZR Differential Housing now available from HPD
1 post in this topic
August 23, 2009 - Princeton, MN:High Performance Design is proud to introduce their new Polaris RZR Differential Housing.These new housings are cast from 356 aged and heat treated aluminum. This alone would make them twice as strong as the die cast originals. They are a minimum of 30% thicker and at least twice as thick in the pinion to output areas. It is highly unlikely that these housings will
More...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
  • Similar Content
    • By RoxanneRoseReid
      Need a polaris manual for a 1994 2 stroke 2/4x4 quad free. can you please post a link I can click on Thank you. Roxanne
    • By buzzar56
      I am looking for a free repair manual for a 2003 Polaris sportsman 500 ho atv. all the posts on here lead me noplace
      thanks fred.
    • By Weldingrod47
      Trying to change front wheel bearings. I removed the cotter pin and castle nut. Hub won't budge. Is there an additional retaining clip? Seems to be one of those push on type that barbs on the thread of the spindle. How do I remove it?
    • By warkcol
      I am having an issue where it sounds like the gears are slipping if I hit the throttle really hard and also after letting off when the engine brake is applied. Also, the drive train that goes to the front also rides again the gear shift box. I will attach pictures and a video here shortly.
      Thanks in advance!
      [ame]
      [/ame]https://postimg.org/image/cdlu6fza9/
    • By Beb1041
      Looking for a download of a manual
