Arizona Dirt Sand Expo Combines with Arizona Motorcycle Expo For One Big Event in De
PHOENIX, AZ – SEPTEMBER 15, 2009: The Arizona Dirt Sand Expo has combined with the Arizona Motorcycle Expo at the Arizona State Fairgrounds for one big show the weekend of December 12th and 13th. With the economic state, the promoters AZ Expos, Inc have changed the structure from a formal show to a SuperSwap with very affordable $100 booth prices. AZ Expos goal is to provide companies the
More...
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By mga
      I just want to clarify that i was doing the timing correct. I wanted to adjust the valves, so, I removed the spark plug, I removed that little black plastic cap on the side, then, i turned the engine counterclockwise until the "T" lined up with the small groove on the threads where that black cap screws in. Then i checked the valve clearances.
      So, what is the "F" mark for?
      I hope the "T" was the right mark to use.  lol
