New Charge Alert Battery Status LED from Rigid Industries
MESA, AZ – September 11, 2009 – The latest release from Rigid Industries is here. A simple 5 minute install of 2 wires and one surface mount LED bulb lets you know the status of your charging system.A simple yet ingenious way to monitor your vehicle battery Status. Install two supplied wires(one to ground, one to switched power) on any 12v wire in your vehicle, mount the led bulb anywhere in
More...
    • By Mhatayas
    • By huntindog
      TIA
    • By Werewolf
    • By vlxerdon
      Don
      I got my no spark issue sorted out, got it running on the old aftermarket carb, but it didn't want to take throttle even after cleaned it, didnt really want to waste time on it, so I order a new one which is on its way, so not much to post here, but I wanted to start a new thread. I am stating to clean up the plastics thought I might as well do that while they are off, they were a mess tree sap, bird dropping, mold and what ever. Washed them good and got all off so I could see the oxidation , decided to wetsand with 600 grit waterproof sandpaper, and used Armour All instead of water. I figured it could put some of the moisture back in that was lost from sun exposure.
      Working fairly well I will keep going finer on the grit and see if it will polish
