Sign in to follow this
Followers 0
utvboard
New Studded Snow/Ice From ITP is Just in Time For Winter
1 post in this topic
ITP TUNDRACROSS IS THE INDUSTRY’S FIRST STUDDED SNOW/ICE TIRELeave it to ITP to deliver the ATV/UTV industry’s first production snow and ice tire! The all-new TundraCross features 96 carbide-tipped steel case studs that are strategically placed for maximum performance on ice and snow. The TundraCross is based on ITP’s highly successful TerraCross R/T xD design, and features fully sipped (thinly
More...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
  • Similar Content
    • By Jw7054
      Alright so I know that they all have their goods and bads. My options are the raptor 660 or 700(probably 700), ds650, outlaw 525, predator 500, or trx700. Before you rant and say this one is the period, I will have a budget of around $3000 tops. So that is however much I spend. After buying a raptor(660), ds650 and predator, I would have at absolute most $1000 dollars left. How ever with the raptor 700, outlaw 525, and trx I would be surprised to have any money left over. Now the extra money
      Now what I know, the ds650 is a pig stock, needs uncorked and tuned and has no reverse but can be a beast and rides good, the raptor 700 is a wheelier and way better than the 660 but neither can hill climb very well, the 660 is tippy and weaker and hard to tune. The outlaw is fast and expensive but rides like a dream but can't power slide, the predator is okay. Good power good shocks, just a good quad but has some reliability issues. And the trx700xx that is a dream but is like 4k and don't come up from sale much. Correct me if I am wrong with any of these statements. So which would u choose AND WHY, I don't give a shit that u can owned a Yamaha since they started making em, why would u choose the one u chose. Thanks, and yes I did post this on multiple forums to get more views and more responses.
      Sent from my XT1585 using Tapatalk
    • By ryan93
      the internet and my tires on my quad are telling me two different things, please help me figure this out and maybe recommend what type of tread to use, dirt riding
    • By Gunny
      Went for a ride out in the desert to look for an old railroad tunnel ... What a Great Day !!
      [ame=http://www.youtube.com/watch?v=unLFQele9bM]14 May 2014 Black Rock To Eureka - YouTube[/ame]
      If you're one of them guys or gals that does everything on a mobile device, you'll have to watch the video here ....
      [ame]
      [/ame]...
    • By FortmanShop
      2000 Bayou misses out about half the time.
      I have done the following
      Cleaned the Carburetor.
      Replaced the plug and check the plug wire, its wire, Checked the plug boot it ohms out at 500 ohms
      Motor has 125# compression.
      I did find a barked place on the pickup coil wiring coming out of the motor case.
      I pulled the cover and ohm the pickup coil. It ohms at 470 ohms. I repaired the barked insulation and reinstalled.
      I replaced the igniter with a new one.
      I was told that the voltage regulator could be the problem so I unplugged it and made made sure the battery was fully charged and started it and ran it off the battery only. Still misses out.
      I added a jumper wire to ground on the igniter to make sure there was not a bad ground somewhere. I also added a hot wire to the igniter to be assured that the key or kill switch was not the problem.
      Nothing I have done has corrected the problem.
      Attached is a video. Note: the video camera does not show what the human eye sees. The timing light does not light when it misses but the human eye sees that it is dim during the times the video shows it not flashing.
      [ame]https://www.youtube.com/watch?v=QlSE7bIhWI8&list=HL1396568821[/ame]
      Any Help any of you guys or gals can give me will be appreciated.
    • By gatorchin
      at the end of last summer, i had re jetted the the carb on my 2001 350 wolverine...i can't remember exactly what the stock size was, maybe a 143 or so?? but i know i put a 147.5 in it...that it..stock air filter, exhaust,etc..anyway, near the end of august and september i had that baby dialed in...once it warmed up, it had great throttle response, more power, and was running like a top...i had some issues with my electric start, but that's for another thread (actually i think there is another thread on here about that problem)..so here comes winter...all winter long it ran like crap, and still is..it wont idle very long before it just stalls out...sometimes when i put it in first gear and try to pull out, it stalls...sometime i can ride it down the road a ways, and if i let off the gas or come to a stop, it stalls....it has a little backfire to it as well..not real loud, but i can hear it inside the carb..now somebody told me that jet size was too big, especially in these colder conditions....somebody told me i had bad gas (water)...thing is i filled it up and have been on that same tank all winter long, becuase i haven't riddden much, mostly due to how it has been runing...i am thinking of selling it and getting something bigger, so i want it to be running like it was last summer...so should i put the stock jet back in ??? should i drain the gas and put new gas in?? or both??
