HD Dune Video from Oregon
By BuckBilly
By kawasig
Hello there
By beast6228
However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it. If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By DarkRider
Hey everybody,
Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
Also just keep in mind this is coming from someone not super mechanical.
Key factors:
Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
