zx6r
2000 Honda 400 EX timing chain tensioner
4 posts in this topic
I was wondering if i need to collapse the timing chain tensioner, and if so how do i do this, i am trying to put my 00 400 ex back together after installing a new piston?
Share this post
Link to post
You will need to take the tension off the timing chain to put the top end back together. Here is a picture in which I have circled the timing chain tensioner. You can just remove the tensioner completely, or back it off with a tiny phillips head screwdriver. The adjustment is in the center of the cap on the outside of the motor that I circled. Take the cover off and stick the tiny screwdriver in the hole.
Share this post
Link to post
on the tensor take out the phillps screw and the is a slot located in the hole witch will lock it in place will you insert the tesioner after bolt up turn the slot in the oppiste dircition to release.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By bradleyheathhays
      I'm going to check the valve clearance on my 2011 Grizz 700 for the first time and I'm also wanting to check the timing, but I'm not sure how to do it. What tool (light gun?) do I need for this job and how is it done?
    • By sloundez
      Does anyone out there know where I can get a functional pair of wheel cylinders for subject ATV? Any suggestions welcomed. Thanks
    • By marcuslachance
      I
      I bought a Honda 250sx 1986 but the exhaust is broken. Apparently it's not possible to order a new one. I checked to order one on others compagny but there's noting.
      Do you know which exhaust it's possible to install. Is there a company who sold an exaust to fit on my 250sx.
      Sorry for my english
      Thank you
      Marc
    • By Npeters
      Im working on a old 1987 honda 125 4 wheeler in the school shop. It will start by getting pulled by another 4 wheeler but wont start with the pull start or Electric Start. When you pull start it it tries to start but when you try the electric start it just turns over but doesnt even act like it wants to start. The spark plug is dry and it shoots fuel out of the back(air filter side) of the carb. Weve had the carb off twice and it is complety clean. What are some things we can try?
    • By vinnied
      I can get about 30 mph (speed) Took the filter off still the same. Took the carb off all the jets look good. All new gas. What else could I look at?
