WeekEndWarrior
2002 Honda Foreman Rubicon TRX500FA drive shaft oil seal
8 posts in this topic
:skeptic:I own a TRX500FA Honda Foreman Rubicon 2002. My son stuck a corn stalk into the front drive shaft oil seal. The shaft that comes out of the front of the motor, going to the front drive axle. I need to know what my options are to replacing it. The seal is ruined. Do I need to tear down the lower unit of the motor to replace the seal or does the drive shaft seperte. Please let me know. Or if anybody knows where I can download a repair manual of the web, or email me one that would be great. Not really wanting to purchase one. I will if I absolutely need to. Any Info would be greatly appreciated. Thxs. WeekEndWarrior.
Share this post
Link to post
I'm not 100% sure on that..but I think it pulls out and you can use a seal puller to replace the seal. Someone else like maybe BuckBilly, will be able to answer that. I think he owns or had a Foreman.
* I changed your thread title to help get you better responses and searches to your topic.
Share this post
Link to post
Just bought an 09 Ruby, Ajmboy. I think Ajmboy is correct on how to pull the seal out. Here is a link for the front diff Fiche Parts
Share this post
Link to post
Thanks BuckBilly and Ajmboy, really appreciate it. Also found out through local dealer shop, that I will have to loosen up the front diff. and pull ahead about and inch, and shaft should seperate and should be able to pull out seal and take off of shaft. . Thanks again. Tim. WeekEndWarrior.
Share this post
Link to post
I checked with the local dealer about your topic, while getting my handgaurds. Told me the samething your dealer told you .
Share this post
Link to post
Thanks BuckBilly, I really appreciate you checking out the seal for me. I already did what they recommended and it came apart. Pulled the seal out. Now just need to go get one at local dealer. Thanks again. WeekEndWarrior.
Share this post
Link to post
No thanks needed. I'm glad to learn anything I can about the Ruby.
Share this post
Link to post
I have the seal out. Numbers on the seal are not visible. The prints/parts break down is kind of complicated to read, and really cannot locate the seal on the prints. If anybody has knowledge of seal number, let me know. I can always call local dealer. Thanks again.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
