bizzbone
2001 Honda Foreman 400 smoking and oil coming out of exhaust
10 posts in this topic
It could be that there is too much oil in the motor, or you are leaking oil past the piston/rings or valve guides.
Share this post
Link to post
If there is that much coming out, it's like DD said..there is too much getting into the combustion chamber. Have you changed your air filter recently? Just curious...make sure it's not clogged.
Share this post
Link to post
What dd said.also check your dipstick for overfill. And check spark plug. If excessivly oily. Might be time for a valve and/or ring job. How many miles on your unit?
All factors
good luck and good riding
doonorth
Share this post
Link to post
sounds as if you have bad piston and rings need to check compression on cyl. also look at spark plug and see if it is black and oily hopes this helps
Share this post
Link to post
It could be that your mixture screw at the bottom of the carb is off a little
Share this post
Link to post
just took one apart doing same thing looks like it need piston rings and a valve job take off the head and look at the valves for soft oil carbon on intake valve and see how slopy the piston is in the cylinder
Share this post
Link to post
first thought,
1.check not over filled with oil.vacuum line could be sucking oil. if dirty drain and replace quick solution could go thicker eg 20w-50 bike oil
2. check filter
3. spark plug what color?
4. compression if on the low side ~120psi its rings or valve. if high could be sticky or broken oil ring( if they are sticky, try SEAFOAM, and or intake cleaner, warm upto temp and add little and rev a little and then add more until it stalls. let sit for 30min and run it until warm and exhaust should stop smoking.
5. take head off check valve guilds.
6. check rings and bore size and roundness
Share this post
Link to post
Dead thread alert. This was one of those one time posters, thread was started over a year ago, he did check in last April, but has not posted since he started this thread.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
