Sign in to follow this
Followers 0
quadcrazy
Ask Mikey Technical Questions
1 post in this topic
Due to his disgruntled behavior Mikey is permanently locked away in the ATVR garage, but he does have occasional Internet access to answer your tech questions.Each month we receive an overwhelming flow of technical questions from our readers. Everyone at ATVR including the night janitor carries an extremely heavy workload so as a last resort we were forced to put Mike Newsom in charge of answering your questions. Mikey is one of the most talented mechanics we know, but it's his off-the-wall remarks and repulsive attitude that keep him locked away in the garage. If you dare to bear his response, send your questions to [email protected]. We promise not to let Mikey use your name and embarrass you in front of your buddies.
Photo Gallery: Ask Mikey Technical Questions - ATV Rider Magazine
Read More | Digg It | Add to del.icio.us
More...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
  • Similar Content
    • By chevyboy
      AL righty I did some trading around this weekend and ended up picking up a few 4 wheelers for cheap. I ended up with this one for $500 in it total and well the guy told me it dropped a valve. I haven't really messed with it at all. But this weekend I am going to try and start working on it some to get it running before winter time frame. So what I am asking is a couple of questions.
      1. First off where do I start I tried pulling the pull cord and could not get it to move at all.
      2. I need to get a service manual for this 4 wheeler where can I get it downloaded for free?
      3. what do I need to look for and how do I go about this really. I do have experience with 4 wheelers but this one is a little different to me than others because its a V2 and I have no clue where to start internal on the engines. Most of my experience is on the outside portion of troubleshooting on theses wheelers.
      Please no smart butt answers as i am new to here but just wanted opinions on where to start. Please and thanks wink:
    • By Mike8623
      Im looking for a atv fertilizer spreader that will spread bagged manure like Walmart sales. Does anyone have any recommendations or what have some of you used that will work with the bagged manure/fertilizer.
    • By toonces
      '11 Grizz 700 here and I ordered Yamaha front lower boot replacement kit 28P-2510G-00 which consisted of 5 parts. The 4 parts pictured plus a plastic bottle of grease...
      First time doing this and the videos I've seen entail removing the entire axle then removing the top boot to get at the lower boot. Now when putting back together the top boot area (even though the boot isn't being replaced) it's suggested not to reuse the old axle retaining ring but to only use a new ring. So, seeing as how the kit I ordered did not come with the 2 (I believe) retaining rings for the top part of the axle or a second bottle of grease for the top boot it looks like I'll need to order some more parts before I can start on this one. Whadda y'all think?
      Looks like I have all the parts (B, C, D, E) I'll need for the lower section...
      So now I need to get the parts (G, H, I, J, K) for doing the top part...
      Also, from what I've seen I think I'll be needing part 26 as well, which I think is an axle retaining clip. So, should I get this part too?
      So now on to these clamps that came in the kit...
      I've seen how other clamps work but not entirely sure about this one. The only retaining barb I can tell that's on this clamp is the little one in the yellow circle. Other clamps I've seen have much larger retaining nubs about the size of the ones with the blue arrows. So I'm guessing for this clip you use pliers to squeeze the blue arrow nubs together then hook using the small nub in yellow?
      And lastly some questions on getting the 27mm axle nut off. I've seen this done with a pneumatic impact gun on a video but I don't like using those things. One way I've seen it described is to jack up and take the wheel off, remove the center plastic cap, replace the wheel and lower to the ground for some traction. Put the machine in park and chock the wheels, then put your wrench on the nut with possibly a breaker 'cheater' bar and crank. Same procedure for putting it on except you would prob use a torque wrench. Does this wound like the best way to get this 27mm axle nut off without using an impact gun? Even though the wheels would be chocked I imagine the gears (in park) would take the brunt of resisting the torque on the nut when it's being forced off. Would this be too much force on the gears?
      Crap I know this is a long post already so sorry bout that. I'll just finish with summarizing my questions which have prob gotten lost in all that writing...
      1) Should I order the full second upper boot kit plus the axle
      retaining clip part # 26?
      2) How to use the retaining clips in the kit I got
      3) Best way to get the 27mm axle nut off.
      Thanks for hanging in there with me through all that
    • By kvf700
      I may be faced with buying a new ignitor for my '04 Prairie 700. I'm considering going the aftermarket route since they offer performance enhancements along with being a fraction in cost compared to a factory replacement.
      Guess that leads to my question, which manufacturers produce the best part? I see glowing reviews for Dynatek but there are also a few complaints about issues out of the box. A good thing, it seems Dynatek is willing to work with the customers on resolving problems.
      If anyone here has experience with them or others, good or bad I'd like to hear it.
    • By toonces
      Anybody know the axle nut size on a '11 Grizz 700?
      Also, could use a link to maybe a youtube video or a how to thread explaining how to change out the lower front boot.
