Guest gamudslinger88
1994 Honda TRX300 4x4 power/idle problems
8 posts in this topic
I got a 94 TRX300 4x4 on trade a few weeks ago and I seem to be having some issues with it. Its in good shape and not ragged out like most. It has a home made snorkel, 2" I think, and seems to have issues with running rich. I replaced the plug and the start solinoid for the choke and it help and ran good til I fouled the plug out again. It blows a little black smoke when you give it gas and spits and sputters. As long as you keep it around 1/4 or better it runs like a champ but under that it sputters and stalls. I am also getting a little fuel in the filter box. It will not idle either. I had planed on rebuilding the carb and putting the stock snorkel back on but I wanted some expert takes on it. I will use it for hunting only so I have no need for a snorkel.
What do yall think?
Share this post
Link to post
OK tried an old trick I used with trucks and it seemed to clear up the problem for the most part. I reved the engine up high and put my hand over the snorkel intake to block off all incoming air then when the engine dies down I remove my hand and bring it back to life by patting the throttle. I did this about 5 or 6 times and it cleared up the idle problem. This trick puts alot of pressure on the carb in the form of vacume which will break clogs and buildups free. It idles like a champ now and the only thing is a stumble while I am cruzing at 1/4 throttle or less. I ordered a carb rebuild kit so maybe that will help. Any thoughts or oppinions will be greatly appreciated.
Share this post
Link to post
You might have some carbon buildup also..That could clear that up too. You might wan to pull that carb off when you can and give everyting a good cleaning.
* Adjusted your thread title to include full year and make.
Share this post
Link to post
Sounds like a sticking float. When you do the carb re-build you will be able to make sure it is adjusted properly and the kit should have a new float valve, that could help too. Make sure to give it a good cleaning too while you have it apart. Blow out all holes with compressed air. Make sure your air filter is clean too.
Share this post
Link to post
What about the snorkle? will it affect the air fuel mixture? I wouldnt think so but I have been told it will lean them out and I have been told it will cause the mixture to run rich.
Share this post
Link to post
If it is too small, it will restrict airflow and make it run rich. Take the snorkel off and see what happens. The thing that makes me think that you have a stuck float or bad seal on the float valve is that you said that you noticed fuel in the air cleaner. This is caused by fuel flooding the float bowl and coming up though the jets into the carb throat and into the air box. Stumling on the low end can also be helped with a fuel screw adjustment or smaller pilot jet.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By sloundez
      Does anyone out there know where I can get a functional pair of wheel cylinders for subject ATV? Any suggestions welcomed. Thanks
    • By marcuslachance
      I
      I bought a Honda 250sx 1986 but the exhaust is broken. Apparently it's not possible to order a new one. I checked to order one on others compagny but there's noting.
      Do you know which exhaust it's possible to install. Is there a company who sold an exaust to fit on my 250sx.
      Sorry for my english
      Thank you
      Marc
    • By Npeters
      Im working on a old 1987 honda 125 4 wheeler in the school shop. It will start by getting pulled by another 4 wheeler but wont start with the pull start or Electric Start. When you pull start it it tries to start but when you try the electric start it just turns over but doesnt even act like it wants to start. The spark plug is dry and it shoots fuel out of the back(air filter side) of the carb. Weve had the carb off twice and it is complety clean. What are some things we can try?
    • By bodatiouskid
      Have a 2002 Polaris Sportsman 700 that only has 34mi. on a carb & ring job.
      Cut the gas off today to drain carb.Now engine will not idle.If I open throttle will run,but let off & will cut off.Can screw idle in with no change.
      What happened? Why did this happen when fuel ran out?
      Please help me,my ATV is a daily driver.
      Please help!!
    • By izzydum1
      Any ideas on what would make a coil not fire? She was running fine, then began slow start. Now wont start at all.
