By quadcrazy
QUADCRAZY NEEDS YOU!
By DarkRider
By kiriyaaoi
By Starsat
The choke lever doesn't stay in position on my 2001 Yamaha Kodiak. The model is YFM 400. I have to hold the lever to the choke position manually for some reason. Any Ideas as to why?
By huntindog
TIA
Similar Tagged Forum Content
no spark Yamaha YMF 250 Bear Tracker No Spark
- bear tracker
- yamaha
- (and 1 more)
- 21 replies
- 9,907 views
- 2 replies
- 3,404 views
- 0 replies
- 1,704 views
- 0 replies
- 1,815 views
- 1 reply
- 2,917 views
