DirtDemons LTR 450 upgrades.
So I got my tax return and dupmped about 2k into my LTR. The list of parts incudes a Precision steering stabilizer, stage 1 Hotcams, Tusk a-arm guards, Armadillo swingarm and chassis skid plates, Lexx MXe pipe and fuel controler, Pro-Tec Moflo airbox lid, ITP Holeshot GNCC rear tires, and Skat-track Edge 8 paddles on matte black G-force XC 10X8 wheels. The paddles will fit all my quads so they aren't just for the LTR, but I plan on buying some Skat-track Haulers for my 500R, so it won't have to share anymore.
I am sure you have all seen a stock LTR 450
This is the machine all stripped down.
Edited by DirtDemon
I would like to start by thanking Hinshaw's motorcycle store for taking such good care of my machine. This is the first time I have even touched this thing as far as maintinece goes, I pre-paid 2 years worth of scheduled maintinence and I don't think I got my quad taken care of very well. First thing I noticed is that the air cleaner was not on all the way and there were several tears in my pre-filter, so plenty of dirt made its way into my throttlebody and surely into the engine. I also noticed that the valves were way out of spec, the intake and exhuast are supposed to be set at .006 and .010, they were all between .003 and 004. I also noticed that the cam bearings have been spinning between the head seat and cam cap. Really freakin nice right? I assure you, they will be getting a very unpleasant visit from me in the near future.
So here is the pipe going in, the slip on mid pipe came with no clamp, so I drilled out the spot weld on the stocker and used it to help hold the pipe on since the fit was not that snug. Other than that, the pipe looks to be well made and fit perfectly, all welds looked good, the pipe does not sit quite centered on the bike, but that is ok, it was only $180 and seems to be made well. It seems like it is a little more restrictive than the uncorked stocker, but, that will change when I take the quiet core out this weekend. The recommended fuel maps for after you remove the core are much more aggressive, so I expect a big improvement.
The fuel controller was simple to install, just unplug the stock connector from the injector and plug the controller to the injector and the stock plug to the controller. I ran the ground wire straight to the negative battery terminal and mounted the controller box under the seat. It is simple to adjust and seems to work flawlessly. The only thing to be determined is how reliable will it be. The are a relatively new company but I have only heard good things from those who have bought thier products, so I decided to take the chance because you can't beat the prices if the parts prove to be reliable.
The Pro-tec Moflow airbox lid is a piece of crap, it doesn't even snap into place like the stock one, it comes with zip ties! No gasket or groove to seal around the sides, and the fit is loose. It will be going right back, so not worth the $90 it cost. I was able to make a similar immitation using the stock lid and an Outerwears box cover. You can see it in the last pic, it is a bit crude at the moment, but it works for now. I will be making improvements soon.
The Precision Racing steering stabilizer was easy to install and works great, I had no idea how much it would improve the handling. I intentionally bumped the front tire into some stumps and rocks to see how well it helpled with bumpsteer and much to my pleasure, instead of the bars jerking, the front tire just bounced off and I hardly felt it in the handlebars. One clamp goes on the steering stem and the body clamps to the frame. You can adjust the center stiffness and the side stiffness separately.
The skid plates were easy to install, but I don't really like the Tusk a-arm guards, the fit isn't perfect, and the mounting hardware doesn't fit quite right, but I think they will do thier job and the price was right. The Armadillo chassis and swingarm plates were pretty good, and the chassis plate paid for itself in the first 15 minutes of the test ride. I flat bottomed on a good sized jump and bottomed out on a big rock. It really messed the plate up and tore it right off the bike, but had it not been there, the frame and maybe the motor would have gotten messed up, the frame suffered a couple small dents, but it would have been much worse without the plate. I was able to mount it back to the quad, even though the rear screw was torn right off. I will be able to straighten it out and fix the rear mount.
The first pic is of the tattered home made swingarm plate I made. I also welded a small plate under the engine as well, it was removed prior to installing the new chassis plate. The next is all the new plates installed and the last few are the mangled chassis plate after the jump.
No pics for the stage one Hotcams. Unfortunately, I did not have the camera handy when I did the cam swap, but, I will tell you, that it is a pain, the shimming process is a pain, but even with the new exhaust still corked, I could tell that these cams made a big difference. The engine seemed to rev higher and faster and I found myself attaining higher speeds much quicker. I think I will really see the difference these cams make when I pull the plug out of that pipe and re-calibrate the fuel controller.
So, I was killing some time at a dealership near my work while I was waiting to meet a friend. I wandered into the clearance room and found these sitting in a box labeled missing mounting hardware. They had the footpeg mounts, just missing the front frame mounts, I picked them up for $80.
3/4" pipe was too small, and 1" was too big to fit in the end of the bars, so I wrapped some 1/16" flat bar around the 3/4" pipe and ground it down to fit inside the nerf tubes.
First, I welded one end to the pipe.
Then I wrap the bar around the pipe as tightly as I can.
Cinch it down with a pipe wrench and score a slot in the end whith a dremel.
Then break it off and weld up the other end.
I then fabbed up some other parts, using a 1/2" bolt with a nylon lock nut, and some 1/4" steel plate. I drilled a 1/2" hole through the skid plate and frame.
After fitting and tacking everything in place on the machine, I took everything off and finnished welding everything together and put a few coats of paint on.
Well, the low dollar Lexx slip on exhuast delivered a great performance increase over the stock uncorked muffler, but it started coming apart on me, the rivets started coming loose and the back of the pipe started coming off, and I lost a spring. Sent it back with the P.O.S. Moflow airbox lid and used that paypal credit towards a Team Alba full race exhuast. Made my own airbox lid by cutting out the stock lid and attatched a piece of Outerwears material to the hole with high temp RTV silicone, works much better and is much less expensive. Will post pics when I get the new exhuast, probably tomorrow or Thursday.
Honestly, the rest of the pipe looks to be pretty well constructed, I called RM and they said it was a common issue with the pipe, and they are actually changing the way they rivet that side of the muffler on. It fit well and performed well, they just made a small design flaw. My friend has the same pipe on his TRX 450 and has not had any problems with it yet. If they are able to get the rivet thing fixed, I would still recommend it for anyone who wants cheap performance.
Any way, the more important thing is that my Alba pipe came today and I put it on fired it up and made a few preliminary adjustments to the fuel controller. This thing is loud, I would not recommend for anyone who wants a quiet or "legal" pipe. Alba warns of this and claims 105 db, I guess they have a quiet core and spark arrestor for it though. I will have a ride report after the weekend, here are some pics of the new pipe on my dirty as* quad.
New and stock header.
New and stock silencer.
New exhuast on quad.
So, I finally got to test the new pipe today, it kicks as*. When I actually got it outside, it seemed like it wasn't going to be as loud as I thought, but after 30 minutes of hard riding, it was noticably louder than when I started. Just as the people at Team Alba advertised, the thing is loud, and power gains are noticeable throughout the power band. There is a notable power increase from bottom to top compared to the stock, unplugged exhuast. As well as a drastic weight reduction. The stock silencer is probably 2-3 times the weight of the Alba. This exhuast seems to make the most of the other mods bringing out the full potential of every thing else I have done. Compared to the slip on, power is much smoother and spread across the powerband, where as with the Lexx slip on, there was a noticeable hit in the mid-range that carried through the top end with no real gain on the bottom end. Bottom end power is now so much better, I am now having a bit more trouble finding traction, even with the GNCC tires, which hook up 10x harder than the stockers or the Razrs that I ran before. Where the machine used to pull the front tires up at will in 1st and 2nd gears, I am now finding a lot of wheel spin, if I want traction, I actually have to make sure not to give it too much throttle. In the upper gears, where traction is easier to find, I find the front tires coming off the ground alot easier, especially when dropping down a little hill, or as I punch the throttle when exiting corners. Overall, I am very pleased with this product so far, especially for the price, only $350 shipped to my door for a full stainless steel exaust system.
Edited by DirtDemon
So I was out in the garage earlier when something caught my eye. I can't believe I never noticed before, but one of my nerf bars is slightly wider than the other. The left one sticks out about 1 1/2" more than the right. It is a production flaw, so I will try and get the the faulty one replaced, but since I got them on a clearance sale with missing harware for $80, I won't be holding my breath . I will most likely cut the rear fender mount off to later relocate it in the proper location and cut the extra lenght out of the horizontal bars somewhere toward the middle and weld them back together. You don't even have to look that hard to see the difference.
Josh this is the first time I am seeing this thread, great write-ups and awesome parts. I would love to give that thing a ride I bet it rips. I am so looking forward to riding soon. I also can't wait because it will be my son's first time on the Blaster. That little thing is scary fast. My father-in-law has him thinking it is as fast as the LT but ya know.
LOL, That is crazy... I wonder if they were on clearance and they just matched up 2 broken sets of nerfs???
They were marked for clearance because they were missing mounting hardware, I don't think they even noticed the mismatched width. It took me 4 months to notice.
I think the outer frame and foot peg bar were just cut wrong, one side is just wider than the other, other than that, they are the same. However, due to the fact that one side is wider, some of the hardware (rear fender mount and heel guards) were centered according to the extra long cut. So to fix it, I not only have to cut out the extra length, I have to move the heel guard,one of the strap mounts and the rear fender mount.
Thanks Scott, you are more than welcome to ride it any time you want to make the trip out to WA. It definately moves pretty good now, I think it would even give my 500R a run for it's money.
The Blaster is a great little machine, I got one when I was 12, I loved it. Coincidentally, when I had the Blaster, my father was riding 250 Quadracer much like yours. I loved my Blaster, but if my dad wasn't riding the Quadracer, I was, I liked it alot better.
    • By semicolon
    • By BruceG
    • By Charlesbrown
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By olddude
      Just wondering where you guy's an Gal's get your parts. I love buying OEM stuff but sometimes they just cost to darn much for what they are. I know, I know everybody needs to make a living but dang! $ 97.00 for brake pads on one side of the front of my KingQuad. There has got to be a better way.
