1999 Suzuki Quadrunner 250 High Idle
I have just bought this and don't have any problems but the idle is really high then it is in neutral and i don't know where the idle adjustment is. I would also like to know what kind of oil i should put in this ATV because he gave me a oil filter so i could change the oil and i forgot what oil he told me to use.
There should be a plastic knob coming out from the left side of the carb, that should be your idle adjustment. You may also want to try adjusting the fuel screw which is located on the underside of the carb toward the front. If neither of those helps or the machine still doesn't run right, you need to start checking for air leaks by spraying carb cleaner around the intake area of the motor.
    • By BruceG
    • By Mhatayas
    • By mehim
      Hi everyone.
    • By N00bie
    • By hardcastle
