2009 Sportsman 400 AWD engine knock at idle
SP400
Alot of the newer 4-stroke motors have a very thrashy sound, especially at an idle. A TRX 450R sounds like it is going to fall apart when it is idling, but as soon as you hit the throttle, it sounds great. Just to be safe, take it to the dealer that you bought it from and have them listen to it, they will be able to give you the best advise.
    • By N00bie
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By DrtyGrlKristin
    • By Drillbit
      Hey all,
      Thanks!
