pineknot
02 300 king quad
6 posts in this topic
Looking for a little insight for what appears to be a fuel issue. Quad starts fine and idles fine, however when riding, it will run fine for about 3 to 4 blocks and starts sputtering and dies. If you give it a couple of minutes it will fire back up and run fine for 3 to 4 blocks and the same thing occurs. Is it possible it would be the petcock is bad?
Thanks Pineknot
Edited by pineknot
lack of description
Share this post
Link to post
Thanks Is there any special way to clean the petcock filter tubes? Or can you check the petcock to see if it is not working properly?
Share this post
Link to post
You could put one of those clear in line filters in-between the petcock and the carb and watch it to see if the fuel stops flowing right before it shuts off.
Share this post
Link to post
Thanks for the suggestion, I'm really confused on this one. I pulled the line off from the carburetor and started the engine, fuel drizzled out in prime and pumped out in the on and reserve position. I've checked the vacuum line to the petcock and the vent line off the carburetor. I'm beginning to think i may have a weak diaphragm on the fuel pump. I'm not sure how to test the fuel pumps vacuum without special equipment. Open to any suggestions.
Thanks Pineknot
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By skgw1
      Feul pump went out. Replaced. At times quad cuts out like its not getting gas. Saw article on new pump needs to be calibrated. Told how to go into a service mode. Does not tell how to calibrate after going into mode. Can anyone shed light on this procedure.
    • By katasha2
      I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused:
    • By Blue
      Hey all I have a question on my 94 fourtrax 4x4. The electric start won't work. When I hit the button I hear the solenoid clicking but nothing happening. I put on a new solenoid and same thing happened. So I took off starter and checked it, brushes looked good nothing looked out of the ordinary. My battery is putting out 11.2 volts. I wouldn't think that would be it since I put a newer battery in from my other quad and still got same results. Any ideas I'm scratching my head on this one.
