2005 Suzuki Eiger Brake light stays on
toadman
There are switches on the brake levers, if you move one of the brake levers back and forth slightly, you should be able to hear a click. That is the brake light switch. My first guess would be that one of those switches is stuck. It could be as simple as backing off an adjustment, or maybe the switch just needs to be replaced.
Once again thanks for helping. I checked the hand levers when the problem first showed up but there didn't seem to be any problem. I haven't been able to look for the foot pedal switch yet but that may be the culprit. I will try to locate that switch on Friday as that will be my first opportunity.
    • By Uglyside38
    • By Mhatayas
    • By BruceG
    • By hardcastle
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
