By DrtyGrlKristin
By p5200
By Werewolf
By Gwbarm
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
Similar Tagged Forum Content
- 7 replies
- 4,515 views
- 1 reply
- 4,588 views
- 5 replies
- 7,296 views
- 3 replies
- 6,857 views
- 0 replies
- 3,285 views
