dajosher69
06 trx450er 450 cc clutch not fully disengaging
9 posts in this topic
i have a 06 trx450er and clutch wont fully disengage it goes through the gears fine but when you put it in 1st gear it starts to go it slips but moves with clutch fully realeased it wont go into nuteral when idleing either i thought to adjust clutch but still did it even up to the point of adjusting it so far that it sliped going through gears please help idk what it could be.
Share this post
Link to post
When I get home I will look in my manual's troubleshooting section... I'm stumped
Share this post
Link to post
Is this something that just started ?
Share this post
Link to post
I just got the bike so im not for sure. when i got it the clutch handle was broken. So i just took for granted. The was that bike was niglected so i've been going through it piece by piece finally got it runing right and now this.it shifts fine and when i'ts not runing it goes through the gears fine. i'ts like something is sticking within the clutch pack wierd never experienced this before with any bike.it either enguages fully or slips. it try's to fall on its face when you put it in gear but understandible due to the fact it lunges forward but pops right in gear and i thought maybe fork was bent thats why i adjusted clutch and i adjusted so far that it sliped when rideing and still the same thing it lunges and has to much pressure on trans to allow it to pop in nuteral while running here is a question though could to much trans lube cause this? cant wait to get it right this bike is a beast much more power then i expected from a 450 supprised me big time. thanks for responses and i hope we can get to the bottom of this.
Share this post
Link to post
it could either be a worn out clutch or a slave/syncro sleeve. If you adjust it till it slips then turn it back until it stops with a slight play in the clutch handle you clutch should be set. but if it slips when it is set then it may be possible to have to much fluid.
Share this post
Link to post
too much fluid or the wrong fluid- another one with car oil in it?
Share this post
Link to post
That's a good point Lawny. Using the wrong oil, or low quality oil could be causing problems too, conventional oils, especially cheap ones, have a tendance to leave deposits, these deposits are likely to build up on things like clutch plates and cause slipping. Automotive oil uses friction modifiers that are not good for wet clutch applications, that will also cause slipping. I would start by changing your oil, and while the oil is drained, take the clutch cover off, take the clutch apart and inspect the clutch components for damage, excessive wear, or deposits on the discs and plates. Make sure all the linkage is in proper order too.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
