Austin20
2000 Honda 400ex smoking
6 posts in this topic
Hi i have a 2000 400ex Sparks full exhaust and jetted and it smokes a blueish smoke.
Why is this thanks A20
Share this post
Link to post
Sounds like its time for a new top end (piston, rings and bore the cylinder if needed)
Share this post
Link to post
Have you over filled the oil? Is it smoking only when first started, during engine rev or all the time? Blueish color smoke is created by excessive oil going into the cylinder.
Share this post
Link to post
Try changing the oil and make use you use correct 4 stroke atv oil with all the additives. As oil breaks down, it can get past the rings into the cylinders. If it's excessive, maybe do a compression test.
* Added manufacturer to thread title.
Share this post
Link to post
Worn piston/rings, worn cylinder bore, or leaky/worn valves, seals, or guides can all allow oil to leak into the cylinder. Most likely you just need rebuild that motor. The more you can afford to replace, the better.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
