cassmanbearcat
changing rear brake pads 2004 ltz400
3 posts in this topic
ive put the new pads in but cant get them to go back on rotor because of the mounting bracket...i can compress the bracket in with a c clap,, but it comes out again when i remove clap.... there is still a allen bolt in the calibur that looks like it is connected to the bracket still... am i supposed to take the bolt out also, is that why the bracket will not stay compressed so it will fit on the rotor? i have tried to remove that bolt but it is extremly tight....
Share this post
Link to post
Is there an adjustment for the rear brakes? Make sure it's all the way backed out.
Share this post
Link to post
sounds like the parking brake adjustment needs to be backed off so the caliper piston can be pushed back into it's bore
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
