predrider305
450r shocks on 400ex?
9 posts in this topic
Sorry if this has already been posted, but i read in DirtWheels magazine(awesome mag) that 450r shocks fit on a 400ex! Wondering if i need any modifications in order to do so? Also, it would make a noticeable difference right? Thanks for any imput :biggrin:
Share this post
Link to post
I think it would make a huge difference! I dont know if you need to mod anything to do it though, but lots of people have done it so someone else should be able to tell you that.
Share this post
Link to post
You will have to shave a small amount off the very top of the shock, where to the bolt goes through. Other than that, they work fine. Very nice upgrade from stock.
Share this post
Link to post
Some people find the 450R shocks to be a bit stiff and tall for the 400ex or 250R. But for a heavier rider this can be a good thing. I think they would work quite well with extended a-arms since the 450R is a bit wider than a 400ex. Overall, I believe they would be a good step up from stock, and much cheaper than aftermarket. I use a set of KFX 450R shocks on my 250R with +2 a-arms, and I think they work great.
Share this post
Link to post
I been thinking of doing this same thing on mine, the stock 400ex shocks are to dang rough
Share this post
Link to post
Yep, "pogo stick shocks" as most people call them. At least with the 450r shocks you get some adjustments to make it work better for how you ride.
Share this post
Link to post
ill definatly be looking into some 450r shocks, rode my buddies 450 the other day and its so much smoother
Share this post
Link to post
Plus the 450r shocks are rebuild able so you can get them re tuned to match you even more
Share this post
Link to post
I did not have to shave the 450 shocks when I mounted them,I just took a screw driver and hammer and knocked off the nut welded to the frame that holds the front plastics above the shock.Then used a smaller carriage bolt upside down and bolted everything right up. The shocks made a big difference.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By Sandy10145
      Hi guys I'm new to the forums and I need some help to make a decision. I recently started riding quads a few months ago and have been riding a Yamaha blaster. I'm now deciding of getting a raptor 350, Honda 400ex, trx450, or yfz 450. At first I looked into the 350 but I wanted more power. Recently I looked into the yfz and read it has a smoother ride and something about adjusting the cylinders? Any information on what I should get, pros? Cons? Would all be extremely helpful.
    • By Snowden
      Hi everyone,
      I have a question, if the starter clutch gear looks fine but is still not working correctly then all I should need to replace is the one way bearing, right?
      thanks,
    • By Muggzy
      Just picked this up over the weekend;
      2001 400ex starts and runs great with fairly new rubber, nerf bars, aftermarket subframe (needs a grab bar), aftermarket bearing carrier & LEX MXe exhaust. Needs bushings and bearings front and rear. Oh yeah and it's got alum wheels too.
      It may be leaking at the bottom of the cylinder on the carb side (cleaned it all off and ran it/road it for an hour or so but didnt see any sign of oil or leaking and needs the chain replaced. picked it up for $1200
      If I take the cylinder off to replace the gaskets, should i do anything else while Im in there?
    • By trx40012
      I have a 07 trx 400ex. I had issues with the shifting. It would shift up to 2nd then hit a roof and go no higher. I took it apart and split the case. The shift drum works fine when shifting by hand or with pliers. But when you use the gearshift plate and shifter it will not move. Any ideas?
    • By Ocala400ex
      i have an 06 400ex, just put on an hmf slip on exhaust, uni air filter with the airbox lid on, new spark plug, 42 pilot jet, and i started with a 160 main and when i checked the plug it looked a little dark so i switched to a 155 main. both jets ran perfectly fine. should i adjust the a/f screw and see what happens?
