pete59edsel
2005 Suzuki Eiger Drive Belt Replacement
7 posts in this topic
Hello, I have a 2005 Suzuki Eiger Quad runner. 400 4x4 Auto, I have spent literally days on replacing the drive belt, can any one let me know what I'm missing or any help would be appreciated!! Pete
Share this post
Link to post
What part exactly are you stuck on?
* Added issue to thread title.
Share this post
Link to post
Just getting the belt over both the secondary and primary, seems so tight, do I need to take 1 of them off first, I can not get the belt on. Thank you!---Pete
Share this post
Link to post
just put the quad in nuetral put it on the primary then roll the quad while putting it on the secondary pulley.
All drive belts are hard to put on. Sometimes nearly impossible. if they weren't the engine would rev out before it grabbed the belt.
Edited by GEARHEAD01
Share this post
Link to post
No, you can not get it on that way...impossible, I know for a fact if you have a 05 Eiger 4X4 automatic you can not put it on that way, show me a vid, then I will believe. Here is the correct and only way...after you get the aluminum cover off, use two of the bolts from the cover and screw them into the two holes towards the center of the secondary/ driven sheeves. turn them in until they just barely bottom out, you will see the secondary expand apart, the belt will also become loose in the process. then take the shaft nut off of the primary and off of the secondary, both sheaves will then slide off together, you can do it by just removing the primary and pulling hard on the belt, I suggest you remove both so that you can wash all of the components, then put it all back together in reverse order. you will have to find a way to hold the sheaves when taking off and tightening up the shaft nuts. they torque to 83 ft lbs. for an eiger. with the primary and secondary back in place with the new belt, then remove the the two bolts allowing the secondary to come back together, spin the secondary clutch counter clock wise to situate/ tighten the belt. Any question feel free to ask, it took me a looong time to get this, I will be more than happy to help in more detail if needed.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
