1998 Honda 300ex Backfires, Stalls, Runs Hot
polaris400
I own a 1998 Honda 300ex The last two times I rode, probably for about an hour,I shut it off for ten or fifteen minutes and when I went to ride again it backfires and then stalls out. Also the motor seems incredibly hot.Then if I let it sit for a long time it starts and runs fine.Can anyone tell me what might be causing this and what will fix it? Thanks a lot!
    • By dhallftworth
      Hi everyone, I received a 98 Yamaha Timberwolf from my brother for free, and I'm working on getting it going.
      I am having the following problem:
      The engine is backfiring through the carb.
      I have done the following to try and get the four wheeler running:
      Rebuilt the carb and set the air screw to 1-1/4 turn out and the circlip at middle position 3
      Replaced the coil, because the cable was loose at the coil end
      Repaired the main ground, coming from the battery
      Replaced the ignition switch, because my brother couldn't find the key. New switch tested good
      Tested the kill switch and it tested good
      New coil tested goodfor both primary and secondary coils
      Pickup coil resistance is at 195, which is correct
      My source coil, is where I believe the issue is. The resistance is 310ohms, and it should be between 428-523ohms
      When I opened the stator housing, there was significant oil, which I have read is normal. Does it sound like I'm on the right track replacing the source coil? Could this be causing my backfiring issue? It looks like the source coil is part of the stator assembly, is this correct? 4BD-85510-20-00 STATOR ASSY
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By 2wdrancher
      Hello everyone I have done a ton of research on doing this conversion because I hate getting stuck in the stupidest places and not being able to back out. I will be documenting my conversion here and on a couple other forums and probably post a couple videos on YouTube. So what I’ve come up with is all you need is a front axles, front propeller shaft, the final shaft inside the engine and the 4x4 front engine cover . I will list all the part numbers for everything that you need and prices from about six months ago (sorry) , you DONT need to switch out hubs, knuckles, or anything like that, and if you want differential lock lock like the foreman and Rubicon you can get a foreman Rubicon front differential and propeller shaft with the diff-lock and get a knight sure four manual actuator for it and voilà you have four-wheel-drive rancher. Input from you guys is greatly appreciated thank you for your time!
      Note: I would definitely get the aftermarket HD axles because they are definitely stronger and are around the same price as oem
      FINAL SHAFT
      23611-HR3-A40  =$80.48
      BEARING
      91006-HP5-601   =$11.11
      OIL SEAL
      91202-HR0-F01   =$ 7.94
      COVER ASSY., FR. CRANKCASE
      11300-HR3-WB0   =$206.99
      PROPELLER SH AFT
      40400-HR3-A20   =$91.50
      FINAL GEAR
      41400-HR3-W50   =$714.88
      FINAL CASE BRA CKET
      50350-HR3-A20  =$7.40
      FLANGE BOLT
      95701-08016-08  =$1.49
      R. SHAFT SET
      44250-HR3-WB1  =$240.64
      L. DRIVESHAFT
      44350-HR3-WB1  =$240.64
      This is all for the 2x4 - 4x4  lever that comes in stock on the ranchers. I would definitely recommend looking for parts for wheelers on marketplace,  or craigslist
      001
      NUT, ADJUSTING
      41560-HP5-600
      $6.51
      002
      CABLE, FR. FINAL CLUTCH
      41570-HR3-A21
      $6.56
      003
      SPRING, CLUTCH CABLE
      41571-HP5-600
      $1.95
      004
      CLIP, CLUTCH CABLE
      41573-HP5-600
      $3.23
      005
      GROMMET, CLUTCH CABLE
      41716-HP5-600
      $3.12
      006
      LEVER, FR. FINAL CLUTCH
      54030-HP5-600
      $8.91
      007
      PILLOW BALL, FR. FINAL CLUTCH
      54031-HP5-601
      $10.87
      008
      BRACKET, FR. FINAL CLUTCH
      54040-HP5-601
      $11.19
      009
      SPRING, FR. FINAL CLUTCH
      54041-HP5-600
      $1.86
      010
      GATE, FR. FINAL CLUTCH
      54050-HR3-A20
      $4.55
      011
      GRIP, FR. FINAL CLUTCH
      54321-HP5-600
      $8.95
      X2 012
      BOLT, FLANGE (6MM)
      90111-162-000
      $2.54
      013
      NUT, SELF-LOCK (6MM)
      90343-ZE6-000
      $1.70
      014
      JOINT B, BRAKE ARM
      95015-32001
      $0.82
      X3 015
      BOLT, FLANGE (6X12)
      95701-06012-00
      $1.34
      Or Forman 520 w diff lock
      FINAL GEAR
      41400-HR4-A21  =$732.49
      PROPELLER SHAFT
      40400-HR4-A20  = $92.54
      And you definitely need the sure four locker for this
    • By Tthartdoor
      Hey, Im new here. Just signed up a few minutes ago.
      Recently i bought a 85 Honda ATC250ES Big Red. It needs a fair bit of work and Ive been trying to figure it out. One problem is the kickstarter being locked up. Just today I got the right side crankcase cover pulled off and the gears in there look great. Does this mean the engine is locked up? To be clear, the engine has never run in my ownership. Thankyou for any advice.
