2003 Honda 400 EX idle screw is loose?
    • By N00bie
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By dhallftworth
      Hi everyone, I received a 98 Yamaha Timberwolf from my brother for free, and I'm working on getting it going.
      I am having the following problem:
      The engine is backfiring through the carb.
      I have done the following to try and get the four wheeler running:
      Rebuilt the carb and set the air screw to 1-1/4 turn out and the circlip at middle position 3
      Replaced the coil, because the cable was loose at the coil end
      Repaired the main ground, coming from the battery
      Replaced the ignition switch, because my brother couldn't find the key. New switch tested good
      Tested the kill switch and it tested good
      New coil tested goodfor both primary and secondary coils
      Pickup coil resistance is at 195, which is correct
      My source coil, is where I believe the issue is. The resistance is 310ohms, and it should be between 428-523ohms
      When I opened the stator housing, there was significant oil, which I have read is normal. Does it sound like I'm on the right track replacing the source coil? Could this be causing my backfiring issue? It looks like the source coil is part of the stator assembly, is this correct? 4BD-85510-20-00 STATOR ASSY
    • By Sofaspud
    • By Am2007
      Hi everyone,
      owner manual
      service manual
      engine manual
