By N00bie
By Louznmemind
By Gwbarm
By dvs1961
By Dalton 3
Well the automatic clutch was slipping pretty bad.changed the oil and filter ( used the proper wet clutch oil ) and now it is even worse.
anyone have any info on where to find clutch parts. I can’t seem to find anything before 2016. Are there other brands that might use the same parts?
