airboat302
2004 Honda 400ex cam gear ques
8 posts in this topic
i have a 04 400ex. i pulled the head to replace valve guide seals and wasnt paying attention to which way the gear goes on in relation to the cam any info would be appreciated.
Share this post
Link to post
Basically you line up the notches on the cam gear in reference to the top of the cylinder head. The cam itself should have the lobes facing down. Before you hook up the chain make sure the crank has the T mark lined up with the notch on the case.
I am probably leaving out steps so if you want, you can pm me and ill email you the honda shop manual
Edited by marioweldinginc
Share this post
Link to post
the shop manual will tell step by step how to do it .. so thats what i would do if he is gonna email it i would go 4 it ..
Share this post
Link to post
Ill email it to you tonight. Its a 99-02 manual but it will work for your 04 as it works fine for my 03
Share this post
Link to post
Let me know if you got the file.
Share this post
Link to post
yes i got it thank you very much i havent been on the computer lately. thank you very much
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By Sandy10145
      Hi guys I'm new to the forums and I need some help to make a decision. I recently started riding quads a few months ago and have been riding a Yamaha blaster. I'm now deciding of getting a raptor 350, Honda 400ex, trx450, or yfz 450. At first I looked into the 350 but I wanted more power. Recently I looked into the yfz and read it has a smoother ride and something about adjusting the cylinders? Any information on what I should get, pros? Cons? Would all be extremely helpful.
    • By Snowden
      Hi everyone,
      I have a question, if the starter clutch gear looks fine but is still not working correctly then all I should need to replace is the one way bearing, right?
      thanks,
    • By Suzukiquadrun
      Hello, i recently bought a 2000 Suzuki LTF500 semi-automatic. I was riding it and found out that its hard to shift into 3rd gear and above. could it be because of the tuning because the rpm might be to high, cuz in neutral it would sometimes rev high by itself? or could it be something in the trany?
      Also it shifts easily when off
    • By Muggzy
      Just picked this up over the weekend;
      2001 400ex starts and runs great with fairly new rubber, nerf bars, aftermarket subframe (needs a grab bar), aftermarket bearing carrier & LEX MXe exhaust. Needs bushings and bearings front and rear. Oh yeah and it's got alum wheels too.
      It may be leaking at the bottom of the cylinder on the carb side (cleaned it all off and ran it/road it for an hour or so but didnt see any sign of oil or leaking and needs the chain replaced. picked it up for $1200
      If I take the cylinder off to replace the gaskets, should i do anything else while Im in there?
    • By chad13cook
      The problem is that it continues to change gears shifting down. Starting in N, down to 1st, 2nd 3rd, 4th, N, 1st, 2nd, etc. If you start in N and shift up, straight to 4th...
      What would cause this and why is it reversed for shifting?
