bobski
07 Arctic Cat 650 H1 clutch noise
11 posts in this topic
Had clutches apart when reringed engine. Now when I come t a stop there is a clanging noise coming from housing It also seems like something doesn't disengage when I come to a stop. It doesn't do it as much if I bring the rpm up a tad when I stop. I read from an old post to clean everything with brake clean. I'm going to try that first, but if anyone has any other Ideas like to hear them. Thanks Bob.
Share this post
Link to post
Does it sound like a bell ringing? Sometimes when you stop suddenly the belt wedges in-between the plates and holds the primary open allowing the clutch to make noise. To me it sounds like a bell through the snorkels.
I would also pull the cover and make sure the primary and secondary nuts are tight, they should have been put in place with red loctite.
Share this post
Link to post
Sort of like a bell. When I slow to a stop it will actually stall the engine.
Share this post
Link to post
If the engine stalls there is definately a problem. Check the two bolts that hold the clutch on. That is the most common problem with them backing off. If this is the case be careful if you still choose to run it so you don't crack the cases.
It could also be the rollers sticking but I doubt it.
Take the clutch cover off, remove the clutches, clean everything with brake cleaner and then reinstall the clutches with red loctite to about 250 ft lbs of torque (check the repair manual for exact number).
Share this post
Link to post
Thanks for the help and insight. Plan to take back apart and clean and re torque both nuts. I'll post my results. Thanks again!
Share this post
Link to post
Did I mention that I also replaced the timing chain when I put the new rings in? That means I had to remove the wet clutch and one-way bearing. Green dot out Bobski. I had the one way bearing backwards. Hope I didn't riun the bearing, might order new one just to be safe. Hope my mistake helps others. Thanks for your insight.
Share this post
Link to post
Ahh so the one way bearing was the other way bearing. Good detective work. Hope it works out
Share this post
Link to post
Glad to see you found the problem. My guess others might have similar symptoms when the one way bearing is bad, it is definitely good information to have.
Share this post
Link to post
What is the benifit of leaving that bearing out? I read that alot of riders take it out.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
