2007 Honda Foreman 4x4 ES with ESP
quadcrazy
Electronic Power Steering? Did you guys see this?
Features & Benefits
New for 2007
Honda's revolutionary Electric Power Steering (EPS) system offers speedand torque-sensitive steering assistance for increased control and comfort under tough conditions.
Front and rear suspension are revised specifically for the Foreman with EPS.
Unique Features
EPS is a unique system consisting of an ECU-programmed electric steering assistance motor and multiple sensors. These sensors measure the handlebar torque applied by the operator as well as the ATV's speed to determine the correct amount of steering assistance required for all conditions. More assistance is provided in rough terrain and at low speeds to decrease the amount of steering effort required, while less assistance is provided at higher speeds and in smooth terrain. This innovative technology also decreases bumpsteer and kickback through the handlebar in all conditions. The sophisticated Showa system includes separate ECU programming for 2WD and 4WD modes, while spring-loaded steering-motor gears minimize play to increase steering feel and feedback at higher speeds.
Traxlok® enables the rider to shift between 2WD and 4WD with the simple push of a switch and provides quiet, smooth engagement with shift-on-the-fly capability.
Torque-sensitive front differential reduces torque steer for less steering effort and, when combined with EPS, provides unmatched 4WD steering effort and precision.
Dual front disc-brake calipers feature a patented built-in scraper system to remove mud and snow from inside the front wheel. This helps to prevent buildup of debris between caliper and rim and ensures consistent braking performance.
Brake pads feature thick, long-wear material with improved mud durability, feel and control. Pads have an internal scraper that gives audible warning when pad life is low.
Standard-equipment oil cooler.
Engine/Drivetrain
Powerful four-stroke 475cc OHV air-cooled longitudinally mounted engine allows direct driveshaft alignment to both front and rear wheels for improved drivetrain efficiency.
The overhead-valve arrangement features angled valves in a hemispherical combustion chamber for straighter intake and exhaust flow for improved engine performance.
Rubber-cushion engine mounting and gear-driven counterbalancer reduce vibration.
Snorkel-type air-intake system is specially designed to resist water intrusion.
Integral electric carburetor heater system improves driveability and ensures smooth operation in cold conditions.
Closed crankcase vent system safeguards against engine oil contamination.
USDA-qualified spark arrester/muffler is constructed of stainless steel.
Traxlok is easily engaged by pushing a switch on the right handlebar. An electromagnetic mechanical clutch unit located on the center of the propeller shaft engages 4WD with a quiet two-way roller clutch. Traxlok ensures smooth operation by employing a magnetic switching mechanism that engages when front and rear wheel speeds vary by less than 6 mph. A 4WD indicator light on the LCD meter shows "actual" 4WD/2WD engagement status.
Electric Shift Program (ESP) provides push-button upshifting and downshifting. The rider shifts simply and precisely with the press of the upshift or downshift button mounted on the left handlebar. An onboard electronic control module (ECM) monitors information from four sensors--engine rpm, countershaft speed, shift drum angle and shift spindle angle--to control the speed of the electric shift motor's gear and clutch engagement. Gear-engagement speed varies according to rider style: The transmission shifts more quickly when riding style turns sporty. A neutral lockout at speeds greater than 2 mph ensures available engine braking when descending hills. For smooth shifting, the transmission cannot be shifted from Neutral to First gear or Reverse gear at engine speeds above 3000 rpm. ESP is not battery-dependent, operating whenever the engine is running. Should the rider ever need to shift manually, the ES model is also equipped with an auxiliary shift lever in the tool kit.
Super-heavy-duty automatic clutch for excellent driveability and towing capacity.
Convenient five-speed transmission with Reverse.
Maintenance-free shaft drive with torque-sensing front differential routes power directly from the longitudinally mounted engine without inefficient directional changes.
Convenient electric starter with auxiliary recoil starter features an automatic internal decompression system.
Wet-sump engine carries a large 3.2-quart capacity.
CD ignition with electronic advance for excellent performance and reliability.
Reusable foam air filter.
Chassis/Suspension
Rugged frame and suspension provide an exceptional 7.5 inches of ground clearance.
Independent double-wishbone front suspension uses KYB shock absorbers to give 6.7 inches of travel.
Steel swingarm and dual KYB rear shock absorbers give 6.7 inches of travel.
Rugged, large-diameter 25x8-12 front, 25x10-12 rear tires provide added ground clearance while maintaining precise handling.
Dual 180mm front hydraulic disc brakes combine with sealed 180mm mechanical rear drum for excellent stopping capabilities.
  • 11 years later...
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By GrizzlyRider
      The 2024 ATVs are out and I was just looking at the websites for Yamaha and Suzuki. The Grizzly and King Quad have come a long way, probably two of my favorite quads over the years. Both of these come with power steering but I almost like the King Quad styling a little more. The plastics haven't changed much over the years either, mayeb a little more rugged. The King Quad racks are more like the Polaris plastic racks (I think they were the first to introduce these) but on a closer look, I think its just plastic covers over the traditional metal racks. The Grizzly still keeps the old style metal racks. I like the display/instrument panel on the Grizzly more.
      2024 Suzuki King Quad
      2024 Yamaha Grizzly
      Thoughts on these two? Here's a pretty good comparison of both 2023 models. I didn't know some of these things like no seat latch on the Grizzly and hydraulic rear brake vs cable. Good video to watch if you are consideting these:
      Grizzly 700 vs KingQuad 750! 2023 Full Shootout!" width="200">
    • By Werewolf
    • By tryn2hrd
      I have a rancher 420 TM that since i bought it has a cold hard shift problem beyond a doubt clutch is not releasing by shift lever. After it gets good and hot it shifts ok. Tried preloading adjustment screw clutch releases and shifts smooth but slips. Have had the clutch out and apart twice for inspection and didnt see anything wrong. Any tips will be appreciated. I've ran out of things to try instead of throwing new parts at it.
      I bought this Eiger about a year ago it has been my runner while i worked on my other projects, except today it wouldnt crank, i suspect it is the  petcock not letting fuel through. When i bought it it had a multitude of problems, but i just ignored those and rode it any way, put it on the back burner while i worked on my other projects with more serious problems, like stuck engine ,wiring harness ripped out, and wheels locked up. Got those all sorted out and since it wouldnt crank today decided it was time to refine this one. When i got it it had a bad Non OEM carb replaced it with a cheap aftermarket until i could find a descent priced OEM to rebuild, and have been riding it ever since. It also had a bad petcock, would only run on prime, neutral light didnt work, no brakes, which are a luxury anyway, but as im getting older luxurys are nice to have, so i guess i will fix those. I paid a little more for this one, $800 but he wanted $1500, because it ran and moved and most things seemed to work, and it didnt smoke, even with the bad carb. Generally 500 is my limit for a non runner, since this one ran i upped my limit a little. So i got it out of the shed before the mice got in it for the winter and started going over it today.
      I would never buy a new camouflaged one because of what you see here, and it almost stopped me from buying this one, but it is what it is, not much i can do for that now, they did look nice when new, i am toying with the idea of replacing the plastics while i can still get them, but am not there yet, expensive.
      I think the snorkel has got to go its not hooked up anyway. Looks like a perfect mouse house.
