Quad Stuck Girls
11 posts in this topic
did you ever go on this website? its like a fetish site for girls getting stuck in hot cars lol ... weird stuff
Share this post
Link to post
Tehm ladies got some beautiful brains!!
Brains LOL :laugh:they can ride my quad anytime !!:yes:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By skgw1
      Feul pump went out. Replaced. At times quad cuts out like its not getting gas. Saw article on new pump needs to be calibrated. Told how to go into a service mode. Does not tell how to calibrate after going into mode. Can anyone shed light on this procedure.
    • By katasha2
      I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused:
    • By superdude811
      Can you put tracks on manual atvs? would it be effective? is 280cc enough to even move them? thoughts/suggestions?
    • By Bwdeaton
      I recently picked up a king quad 700 that doesn't run in the hopes of getting it running by spring. It had been previously taken apart some and a few pieces are missing in the engine, but the frame is complete and in good condition. The motor will need a piston, rings, cylinder, cams, and a few misc parts that are missing. Also the cases will need to be split to remove the pieces of piston that are in the crankcase. The piston blew up at high rpm and did a number on the cylinder so I'm trying to find out if it would be worth rebuilding this motor it buying another engine to swap in. There may be more damage to this engine that I can see so I was wondering how bad the insides of it could be considering it destroyed the piston. I have found a motor for 1200 plus 200 shipping, the only problem is I don't have that much now and I would have to save up a while before being able to afford it. Any suggestions appreciated.
    • By franksatv
      i have a warrior 350 and looking to upgrade. i either want a trx 400 or a trx 450. but i feel like im going to grow out of the 400 so fast. but 450 i feel like the 450 will be to powerfull. plz help!!!!!
