Suzuki King Quad 300 - Start-In-Gear Mod
By Gwbarm
By Kawiherder
By adr94
Hello,
I was able to repair most of the little problems on my 2006 BRUIN. I still have little things to do...
I changed the Hazard light Switch because it was not locking when pushed and now it is not working at all. When I connect it (not sure of the wiring -4 wires but a lot of connection possible on this HELLA 3916-01 switch-) the flashing lights button (on the handlebar) is acting like the Hazard light switch.
By Gwbarm
By Uglyside38
Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
