Alternatives to go pro for riding video
By Suzukiquad
I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
By huntindog
TIA
By Frank Angerano
By That229Yamaha
Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
By alexwv1863
Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
Similar Tagged Forum Content
- 4 replies
- 2,733 views
- 0 replies
- 2,505 views
- 1 reply
- 3,893 views
- 52 replies
- 13,379 views
- 4 replies
- 2,372 views
