Gadget44
cdi wiring
3 posts in this topic
new racing cdi trz50 wiring for predator 90
cdi has a green and yellow wire going to a 2 pin plug
and has a red a black and blue with bullet connectors what wires go were on the the ate wiring harness
and how would i wire if i want to bypass the atv harness
Share this post
Link to post
  •  Like what you are reading? Please help us by sharing this content.
ok i fig it out so if any body out there is wanting to know in the future the cdi box is the new racing trz50 cdi box it has the 2 wires in the plug one is yellow and the other is green the green is the ground that the yellow goes to the coil the solid red goes the black with red stripe and the blue goes the white with red stripe and the soil black wire is the kill wire it took some digging and playing
Share this post
Link to post
The black goes to what the black with white
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By Fireuzercut1
      I have a 08 TGB Outback 425 had it running yesterday went back to start it later didn't start checked and no spark went over all wires and connections can't find problem the atv has all good fuses need help.
    • By BigTrees
      Hello everyone, I have a new to me 86 Bayou 300 that I just bought last night to get around the property. It wouldn't start when I bought it but it did turn over with starting fluid, PO said the carb neeeded cleaned. I cleaned the carb today but need to get the choke wired up as it was not wired up when purchased.
      I'm hoping one of you can help me get this choke wired up. Coming from the carb it has 2 wires. 1 is yellow and 1 is black. The PO said I needed to ground one and put the other one on a switch.
      Should I do it this way or is there another/better way to do it? I'd really appreciate any help I could get!! Thanks in advance!
    • By arrested609
      Can anyone please tell me where i can get a good wiring diagram for my Kazuma Falcon 150 cc atv. I have tried numerous web sites looking. I have found some, but the picture was horrible couldn't even read it. Thanks, Craig.
    • By kvf700
      I may be faced with buying a new ignitor for my '04 Prairie 700. I'm considering going the aftermarket route since they offer performance enhancements along with being a fraction in cost compared to a factory replacement.
      Guess that leads to my question, which manufacturers produce the best part? I see glowing reviews for Dynatek but there are also a few complaints about issues out of the box. A good thing, it seems Dynatek is willing to work with the customers on resolving problems.
      If anyone here has experience with them or others, good or bad I'd like to hear it.
    • By colt
      Here is what I have collected over the years and maybe it will help someone else.
      There are so many and several are too large to upload as attachments, so see any thing you need just shoot me a PM and your email and I will get them on the way to you as fast as I can.
      50cc to150cc Service Manual For Tank Motorsports.pdf
      linhai-atv-service-manuals-linhai-300-parts-manual.pdf
      1986 CH250 ELITE SERVICE MANUAL.pdf
      Charging and ignition systems for atvs.pdf
      Dinli-501-PARTS-DINONP.pdf
      Dinli-601-Parts2003BEAST-DIAMONDBACKNP.pdf
      Dinli-DL-5015erviceManual.pdf
      Dinli-DL-502PartsManual.pdf
      Dinli-DL-5025erviceManual.pdf
      Dinli-DL-503PartsManual.pdf
      Dinli-DL-601,DL-603ServiceManual.pdf
      Dinli-DL-603PartsManual.pdf
      Dinli-DL-604PartsManual.pdf
      Dinli-DL-701PartsManual.pdf
      Dinli-ServiceManual-150ccATV.pdf
      DTE150-2-150cc.pdf
      GY6_Top_End_Rebuild.pdf
      Leopard-parts.pdf
      Linhai_260servicemanual.pdf
      Odes-400-Repair.pdf
      Roketa-ATV-10(ATV-DO43)-Repair.pdf
      Roketa-ATV-11(ATV-D037)-Repair.pdf
      SLA-120-PARTS.pdf
      SLGK-110-PARTS.pdf
      SLGK-150R-PARTSMANUAL.pdf
      SLGK-400R-PARTS.pdf
      SLU-500-600-700-PARTS.pdf
      slu700db-700UTV-Service-Manual.pdf
      tao-tao-atv-parts-cylinder-rebuild-kit-for 90cc-100cc-110cc-engines-p-13331.pdf
      Trouble Shooter Guide for BATTERY DRAINED Chinese Engines.txt
      Trouble Shooter Guide for NO-COMPRESSION.txt
      Trouble Shooting No Crank.txt
      Troubleshooting.pdf
      YX125CC BREAKDOWN.pdf
      _________________________________________________________________________________
      50 to 150cc GY6 Shop Manual.pdf
      Arrow 150 Engine Service Manual.pdf
      Eton Shop Manual YXT-150.pdf
      GY6 Shop Manual.pdf
      Yerf Dog Spiderbox GX150 Service Manual.pdf
