CDI box for Yamaha 1995 Moto 4
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
By kiriyaaoi
By Admin
CARFAX https://www.carfax.com
By luckyyyyesther
Hey all!
By jashadams
Snapchat-1142015191.mp4
