Ds650 baja starting problem
Ok guys needs some help asap ready to set this thing on fire..thing would never start valves were tight i adjusted the calves to correct shims on intake n exhaust have plenty of clearance in between cam lobes n shims..problem is i done set tdc about 10 times now its dead on..will not fire one hiccup sprayed gas into carb while cranking n while not all it does is make a loud backfire n some flames come out. Its like valves are tight but  there not.idk how it could be firing wrong with it at tdc. I need help asap
It’s most likely 180 deg out of time. It’s very easy to make this mistake.
There are also a few different marks on the flywheel. Make sure that you have the correct mark and make suite it’s on the compression stroke when aligning with the cam.
Aside from the few things listed above the only other things I can think of is the timing chain is jumping off of the sprockets ? Or the pick up coil is loose delivering the spark at the wrong time.
Yea figured it was out of timing as well but set it tdc then aligned cam marks parell to head cams facing away from each other.. There is only one mark on flywheel. Other marks are lil punch marks about 4 or 5 of them around flywheel..tensioner is working properly so its not jumping teeth..sounds like it sparking at wrong combustion..how would i check to see if its not 180 out?
So let’s back up for one second and recap.
Did you pull the head off of so why?
Did the bike run while you own it?
reason I’m asking is in my experience I’ve missed things during a rebuild back in the day and had to go back to see where I failed.
You are missing something. I looked at the manual and can see that there is only one timing mark that’s labeled “c” ?
The  lobes state they should be facing downward and there is a small hole on tye cam sprocket that should be on top ?
I would go back double check that. If all looks right then I would look at tye triggger cool maybe it’s loose ?
Can you post a few pics of the timing marks you see on tye engine as well as the top end cam and sprocket ?
Yes i pulled head off to instalm new shims.no guy said all he did was changed starter clutch n it would never fire for him after that so i reset timing n still nothing. Cams dowward as in tapered part touching valve buckets? If thats the case then yea there off. I have them at 45° facing away from each other as cam sprokets marks are parallel to face of head.
Yeah I’ve got an 07 board out 30 over and when I go to start mine at either spins without catching the flat will or when it does catch I hear almost like a grinding sound like my clutch has blown apart or something and interested to read more about this I’m new to the four stroke game but Damn sure impressed by the amount of torque and just raw power this thing has. First time I test drove it I actually scared myself which gave me a healthy dose of respect for it.
My 2007 ds650 has a similar starting problem, but not as extensive. I can push start Mine anytime and it will start but when I go to use the starter it just spins and sometimes makes a grinding sound not sure what exact parts I need.
  • 7 months later...
You need a sprag clutch but before you order pull your side cover off. Take off the single big nut and washer....THEN your gonna have to order a flywheel puller( not expensive) ok after magneto pops off on the inside is where your problem  is. Should be eight smaller bolts holding a gear to the mag, four of which hold a sprag cradle/housing. Mine was all chewed up and barings were all over the place/ . Now behind the mag and gear you have large starter gear/flywheel. You wanna check the outcroped landing inwhich the sprag rose on. It can’t have any livers or to many dings or problem will repeat itself if not worse. You can find a sprag for as little as twenty or the flywheel and sprag for like  a hundred. Make sure you follow tork specs and use lock tight when putting things back together.
    • By mehim
      Hi everyone.
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
    • By kiriyaaoi
    • By CaptJim
      Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
      The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
      Can someone tell me where these wires go?
      Thanks in advance for all help!
    • By DarkRider
