2005 Polaris Sportsman 800 EFI Low Idle
  • Ajmboy changed the title to Polaris Sportsman 800 EFI Low Idle
9 hours ago, colin james said:
What is the reading of  your tps sensor. I belive it should  be .95 volts.
As stated  in my last post the only adjustment to the idle is the tps sensor. And there is not much adjustment on that
Hey Collin thanks but I am not sure what the TPS sensor is or how to get the reading you are asking about.
  • Ajmboy changed the title to 2005 Polaris Sportsman 800 EFI Low Idle
Should be on the side of the thotte boady with 2 screws with a 3 wire electrical conection. 1 wire will be 5 volt reference , 1 will be ground  and 1 will be the signal wire that goes back to ecu. If you have a hand held multimeter you can check check the signal by back probing  and setting meter to lowest DC scale. Or if you don't feel  comfortable testing the wiring and  can get to the sensor easily, start the engine loosen the screws that hold sensor and slowly rotate sensor 1 direction rpms should drop the other they should increase. Be careful and do not force anything.
  • 5 months later...
    • By rgeiser
    • By N00bie
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
    • By Charlesbrown
