DeadAim
Fav. Sport Quad of all time
17 hours ago, wylde1 said:
I have been really thinking about that also, but waaaay out of my budget.
Yep, I hear you...plus my wife wont let me spend the money...lol!
Share this post
Link to post
  • Similar Topics
    • By Dra O
      posted a while back - it was running at one point - I have all the plastic shroud off - it's down to frame and engine now
      -fuel pump: when line from petcock is attached, no fuel comes out other side to carb; the line to the carb is open (can blow through it); I thought when I cranked engine that the pump would spit out fuel on other side but it does not; I removed fuel pump and opened it up - diaphragm looks good - but internal areas had lotsa calcification build up - I cleaned this out and dried it good - the clear plastic pieces (?diaphragms) aren't broken - the spring w/ steel ball on end moves freely; am putting it back on tomorrow; but can anyone answer about the pump? isn't it supposed to pump fuel through it... to other side... to carb? puzzling
      -along with fuel pump: I replaced petcock 3 weeks ago (gas tank had rusty fuel in bottom - cleaned it out prior to new petcock); when I turn petcock arrow NOT to on or reserve, fuel comes out of line; when I turn it to on or reserve, fuel doesn't come out; puzzling
      -I don't know what's on back of fuel pump - it's a valve that has a hose coming out of it - looks like it goes to engine/carb - I haven't traced this out yet - what is it?
      -can squirt gas on air filter and engine will run for 2-3 seconds then stop - fuel in top of carb (under diaphragm) does same
      -it likely needs carb rebuild - will get to this - but something isn't allowing fuel to get from fuel pump to carb
      -I THINK it has a mikuni model x carb - diaphragm is ID 26mm  OD 68mm - hard to find inexpensive diaphragm, I guess because it's a model x
      -last thing - I replaced solenoid due to old one clicking; I HAVE to be charging the battery or it won't start/turn over - battery just goes dead; but if charging, it'll turn over nicely; i'm guessing it's a bad battery
      -any help appreciated - I've never owned an ATV before - inherited this beast from grandparent in-law
    • By Ed Zeppeli
      Hi,
      Oddly I'm having  a hard time ordering front brake shoes for my '98.
      I'd appreciate recommendations on decent, widely available shoes if possible. Ideally available in Canada on short notice.
      Thanks much,
      Warren
    • By Rich1028
      Leota Quad Trails  on New to us  Machines 5-10-20
      We Just Picked up two Quads Friday,and we took them out riding,great machines!
      2008 Honda 400 Ex and a 2014 Honda 400 X
    • By hornythrony
      Hey I have a 07 king 700 there's lots of times that the quad will stall when the fan turns on also have to bump motor 2 or 3 times before starting to start it (makes fuel pump go on 2/3 times) anyone having or had this issue?
  • Similar Tagged Content
    • Guest Fox300exchic
      By Guest Fox300exchic
      The Hop-Up: You may be saying to yourself, “that’s a chick bike,” and you’re right. But honestly, it’s so much more than that. It’s one badass bike. http://www.quadmagazine.com/quad/features/article/0,24942,1587044,00.html
    • By katasha2
      I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused:
    • By Jw7054
      Alright so I know that they all have their goods and bads. My options are the raptor 660 or 700(probably 700), ds650, outlaw 525, predator 500, or trx700. Before you rant and say this one is the period, I will have a budget of around $3000 tops. So that is however much I spend. After buying a raptor(660), ds650 and predator, I would have at absolute most $1000 dollars left. How ever with the raptor 700, outlaw 525, and trx I would be surprised to have any money left over. Now the extra money
      Now what I know, the ds650 is a pig stock, needs uncorked and tuned and has no reverse but can be a beast and rides good, the raptor 700 is a wheelier and way better than the 660 but neither can hill climb very well, the 660 is tippy and weaker and hard to tune. The outlaw is fast and expensive but rides like a dream but can't power slide, the predator is okay. Good power good shocks, just a good quad but has some reliability issues. And the trx700xx that is a dream but is like 4k and don't come up from sale much. Correct me if I am wrong with any of these statements. So which would u choose AND WHY, I don't give a shit that u can owned a Yamaha since they started making em, why would u choose the one u chose. Thanks, and yes I did post this on multiple forums to get more views and more responses.
      Sent from my XT1585 using Tapatalk
    • By Weldingrod47
      Trying to change front wheel bearings. I removed the cotter pin and castle nut. Hub won't budge. Is there an additional retaining clip? Seems to be one of those push on type that barbs on the thread of the spindle. How do I remove it?
    • By skgw1
      Feul pump went out. Replaced. At times quad cuts out like its not getting gas. Saw article on new pump needs to be calibrated. Told how to go into a service mode. Does not tell how to calibrate after going into mode. Can anyone shed light on this procedure.
