colin james
2017-2019 sportsman 450/570 with eps factory service manual
2 hours ago, mrfreeze00 said:
well I have a 2017 sportsman 570 and it will not start... It started acting up randomly by not starting every time and now it will not start at all and I mean it will not turn over. I have power to everything just wont try to start.  I have checked the battery, starter, starter solenoid, most wiring from all 3 I have  jumped the solenoid and it will start so I think some where in the starter circuit I have a bad connection or wire that's why I need the wiring diagram to trace it down.
Starter switch?
Share this post
Link to post
Thanks for the manual it is appreciated
Share this post
Link to post
  • Similar Topics
    • By colin james
      View File 2018/2019 Polaris Sportsman XP 850/1000 Service Manual
      This is the factory service manual for the 2018/2019 Polaris Sportsman XP 850/1000
      Submitter colin james Submitted 08/01/2019 Category Polaris ATV
    • By bodon
      Anyone know what the fuse terminal marked UNSWITCH  does  .  Even with the key off it is causing a drain on my battery and I'm trying to figure out  what that terminal goes to.  It's a 10 amp fuse. If I pull it the "short" goes away.  Thanks in advance.
    • By Jeremy Morris
      If you're getting that pesky leaky seal on the pinion of your front differential and the pinion has allot of play, polaris won't sell the bushing needed to repair it properly without having to shell out big bucks for the complete ring and pinion kit.
      I have a kit with an upgraded bushing, Japanese made bearing and USmade seal
      50 shipped in the US and 55 to Canada
    • By Chase Cook
      I have a Polaris sportsman 500 and I just replace the piston in rings and head gaskets on it and I made sure the timing was exactly right it's getting gas and fire but it still won't start. It sounds like it has low compression but at the same time it sucks in air pretty good from the intake. Also the valves are adjusted to spec. It did start the first time I installed the Piston and Rings but it only stayed running for 5 seconds with starting fluid and then it shut off and then I tried to turn on the next day and it didn't do nothing and I've been going at it for three weekends now and it still ain't doing nothing. I wonder if i set the timing off a little or a lot if it would start up, because I inline the crankshaft sprocket with the crankcase timing line like it said in a manual and the two points on top of the cam sprocket to top dead center of the piston. I even took the spark plug out and stuck a camera light in there to make sure it was top dead center and it still won't do anything. AlsoI drain the carburetor some and shut d fuel petcock off to see if it was getting too much gas and that still isn't the problem. And where I live all the darn mechanics that work on Polaris ATVs are booked for two weeks which sucks and I need hope immediately or I'm just going to set the ATV on fire because I'm getting very frustrated with this crappy brand. Every other name brand ATV I worked on I got it running right and I replace the piston, rings and everything etc, and they started up fine. But this is starting to get very frustrated and I don't know who to talk to who had this problem before, who "don't have to come look at it". Cuz when they say that that means you're not going to come look at it until 2-4 Weeks later because there booked, which I don't have time for. Living in northern part of Florida sucks.
  • Similar Tagged Content
    • By Chase Cook
      Hi I just got an Polaris sportsman 500 4x4 ATV the other day. I got it real cheap but I started to go into it because it didn't have compression so I bought a new piston and ring kit for it and installed it, but now when I try to start it all it does is shoot fire out the exhaust or the intake of the carburetor. And a timing is top dead center.;I think I can't really tell another way if it is or not. when I put it together I made sure to piston was on top and the cam lobes where facing down where are the cam sprocket is facing up. It has gas and spark. It did start a couple minutes ago but it didn't stay running and now it won't start. Do you think the valve need to be adjusted more to close better?I'm fixing to try that out and if that don't work what is the problem? Also I made sure everything was together good and right and change the oil and changed out the radiator fluid.
    • By Brian Sosebee
      I just rebuilt my 03 sportsman 400. Put everything back together added oil per the manual. Pinched off the oil tank vent line 2" away ran for 45 seconds then cut it off. Check oil level and it was still way high so I wasn't confident that it primed so I did it again. Checked again and it's the same. Remove the oil filter and it is dry. I did the procedure again and the same results.
      I'm worried to keep trying this as the only oil in the engine is what I used to lubricate the parts when reassembling the piston. The crankcase was drained as well.
      I Removed the oil tank and checked all the lines for obstructions and the screen filter and the vent hose and everything is clear. I even pulled a small vacuum on the oil tank while it was pulled off to make sure there were no leaks. The dipstick cap was on tight so I'm not sure why this thing is not priming.
      Anyone have any suggestions. I thought about pre-priming the oil lines from the oil tank to the crankcase to hopefully help the system prime. I'd like to be able to add some oil to the crankcase to so I wouldn't feel so bad about running the engine for another 60 seconds without oil. I dropped just a little bit of oil in the spark plug hole to help condition the sleeve right now.
      What do I do? Anyone had or heard of an oil pump failure on these. Btw oil pump is working fine before I did the top-end rebuild and the oil pump was not touched.
      Please help!!! Thanks all for any and all help.
    • By jay rear
      Hi im new to the site. I have a 99 sportsman 500. I has been sitting for about a year now. I bought a new battery for it the other day and now i dont have any power to anything but the winch. Any help would be great. I already cut the pouch and checked voltage on both sides of the circuit breaker.
    • By dany desbiens
      Hello i have a Polaris 2003 sportsman 600 Polaris Sportsman OEM Gauge Speedo Speedometer Display Dash Cluster 3280425 the speedo is not working no 4*4 i can find nothing can i put a speedo 2004Speedometer Gauge Speedo
      3280431 04-08 Sportsman if it will work
    • By turner_clint77
      Just have a couple questions
      first does anyone else have an issue with the right hand tie rods coming loose
      second does anyone else’s power steering making a weird sound at times
